All Details Phone import
Hi All,
     I'm going through an CUCM upgrade and am using the phone export "All Details" on a cluster version 8.X, massaging the data and trying to import into version 9.X however I'm getting an error saying the field "CALLING PARTY TRANSFORMATION CSS" is invalid.  When I delete that column in excel I get an error saying the " " field is invalid?  Is there a way around this error?  Anyone else run into this?  Error below:
Insert Phones - All Details
Begin Time : 08/07/2013 13:00:17
Query :
Insert Phones in /common/bps/csvfiles/phones/insert/all/test101s.txt
Failure Details :
MAC Address/Device Name Error Code Error Description
is not a supported field.
Result Summary :
INSERT for 589 PHONES could not be processed.
INSERT for 0 PHONES passed.
INSERT for 0 PHONES failed.
End Time : 08/07/2013 13:00:27
Thank you..
So when I was doing my last upgrade and export all details with phones I took an export from both version and then compared the headers... Highlighted any differences and change any fields that may have be renamed to the new version.
Let me try to see what you are experiencing between 8 and 9.
Thanks for the reply Gregory, I tried that but no luck.  I ran an export from a version 8 server and the "calling party transformation CSS" column is there.  I then ran an export from the new version 9 server and that column isn't there.  I deleted that column from the version 8 export and got the error saying (blank) is not a supported field.  Is it a cruel joke from Cisco or am I missing something easy to fix this?...lol
Re: All Details Phone import
Can you compare your headers against these
From 8.xDevice NameDescriptionDevice PoolPhone Button TemplateCSSAAR CSSLocationExtension MobilityNetwork LocaleMedia Resource Group ListUser Hold MOH Audio SourceNetwork Hold MOH Audio SourceDevice User LocalePacket Capture ModePacket Capture DurationBuilt in BridgePrivacyRetry Video Call as AudioIgnore Presentation IndicatorsSoftkey TemplateModule 1Module 2Phone Load NameModule 1 Load NameModule 2 Load NameInformationDirectoryMessagesServicesAuthentication ServerProxy ServerIdleIdle TimerMLPP IndicationMLPP PreemptionMLPP DomainDevice TypeUser ID 1Common Phone ProfileOwner User IDAllow CTI Control FlagDevice Presence GroupDevice Security ProfileDevice Subscribe CSSUnattended PortRequire DTMF ReceptionRFC2833 DisabledCertificate OperationAuthentication StringOperation Completes ByDevice ProtocolSecure Shell UserSecure Shell PasswordXMLDial RulesCSS RerouteRerouting Calling Search SpaceDTMF SignallingDefault DTMF CapabilitySIP ProfileMTP Preferred Originating CodecLogout ProfileMTP RequiredDigest UserSignaling PortOutgoing Caller ID PatternCalling Party SelectionCalling Party PresentationDisplay IE DeliveryRedirecting Number IE Delivery OutboundRedirecting Number IE Delivery InboundGatekeeper NameE.164Technology PrefixZoneMotorola WSM ConnectionSubscriber Cellular NumberFollow me only when caller has dialed cellular numDisable Application Dial RulesAAR GroupLogged Into Hunt GroupRemote DeviceDevice Mobility ModeCommon Device ConfigurationMobility User IDDND OptionDND Incoming Call AlertDo Not DisturbJoin Across LinesSingle Button BargeBLF Audible Alert Setting (Phone Idle)BLF Audible Alert Setting (Phone Busy)Calling Party Transformation CSSUse Trusted Relay PointServices ProvisioningMobile Smart Client ProfileOutbound Call RolloverPhone PersonalizationProtected DevicePrimary PhoneGeo LocationAlways Use Prime LineAlways Use Prime Line for Voice MessageHotline DeviceSecure Authentication URLSecure Directory URLSecure Idle URLSecure Information URLSecure Messages URLSecure Services URLSRTP AllowedFeature Control PolicyModule 3Module 3 Load NameDevice Trust ModeAllow presentation sharing using BFCPMobility Identity NameMobility Identity Destination NumberMobility Identity Answer Too Soon TimerMobility Identity Answer Too Late TimerMobility Identity Delay Before Ringing CellMobility Identity Time ZoneMobility Identity Is Mobile PhoneMobility Identity Enable Mobile ConnectMobility Identity Mobility ProfileDirectory Number 1Route Partition 1Voice Mail Profile 1Line CSS 1AAR Group(Line) 1Line User Hold MOH Audio Source 1Line Network Hold MOH Audio Source 1Auto Answer 1Forward All Voice Mail 1Forward All Destination 1Forward All CSS 1Forward Busy Internal Voice Mail 1Forward Busy Internal Destination 1Forward Busy Internal CSS 1Forward Busy External Voice Mail 1Forward Busy External Destination 1Forward Busy External CSS 1Forward No Answer Internal Voice Mail 1Forward No Answer Internal Destination 1Forward No Answer Internal CSS 1Forward No Answer External Voice Mail 1Forward No Answer External Destination 1Forward No Answer External CSS 1Forward No Coverage Internal Voice Mail 1Forward No Coverage Internal Destination 1Forward No Coverage Internal CSS 1Forward No Coverage External Voice Mail 1Forward No Coverage External Destination 1Forward No Coverage External CSS 1Forward No Answer Ring Duration 1Call Pickup Group 1MLPP Target 1MLPP CSS 1MLPP No Answer Ring Duration 1Line Text Label 1External Phone Number Mask 1Maximum Number of Calls 1Busy Trigger 1Visual Message Waiting Indicator Policy 1Ring setting (Phone Idle) 1Ring Setting (Phone Active) 1Caller Name 1Caller Number 1Redirected Number 1Dialed Number 1Line Description 1Alerting Name 1ASCII Alerting Name 1Line Presence Group 1Secondary CSS for Forward All 1Forward on CTI Failure Voice Mail 1Forward on CTI Failure Destination 1Forward on CTI Failure CSS 1Display 1ASCII Display 1ASCII Line Text Label 1AAR Destination Mask 1AAR Voice Mail 1Forward Unregistered Internal Voice Mail 1Forward Unregistered Internal Destination 1Forward Unregistered Internal CSS 1Forward Unregistered External Voice Mail 1Forward Unregistered External Destination 1Forward Unregistered External CSS 1Hold Reversion Ring Duration 1Hold Reversion Notification Interval 1Retain this destination in call forwarding history 1Audible Message Waiting Indicator Policy 1Recording Option 1Recording Profile 1Monitoring Calling Search Space 1Calling Search Space Activation Policy 1Allow Control of Device from CTI 1CPG Audio Alert Setting(Phone Idle) 1CPG Audio Alert Setting(Phone Active) 1Park Monitor Forward No Retrieve Ext Voice Mail 1Park Monitor Forward No Retrieve Ext CSS 1Park Monitor Forward No Retrieve Int CSS 1Park Monitoring Reversion Timer 1Park Monitor Forward No Retrieve Ext Destination 1Park Monitor Forward No Retrieve Int Destination 1Park Monitor Forward No Retrieve Int Voice Mail 1Party Entrance Tone 1Log Missed Calls 1Directory Number 2Route Partition 2Voice Mail Profile 2Line CSS 2AAR Group(Line) 2Line User Hold MOH Audio Source 2Line Network Hold MOH Audio Source 2Auto Answer 2Forward All Voice Mail 2Forward All Destination 2Forward All CSS 2Forward Busy Internal Voice Mail 2Forward Busy Internal Destination 2Forward Busy Internal CSS 2Forward Busy External Voice Mail 2Forward Busy External Destination 2Forward Busy External CSS 2Forward No Answer Internal Voice Mail 2Forward No Answer Internal Destination 2Forward No Answer Internal CSS 2Forward No Answer External Voice Mail 2Forward No Answer External Destination 2Forward No Answer External CSS 2Forward No Coverage Internal Voice Mail 2Forward No Coverage Internal Destination 2Forward No Coverage Internal CSS 2Forward No Coverage External Voice Mail 2Forward No Coverage External Destination 2Forward No Coverage External CSS 2Forward No Answer Ring Duration 2Call Pickup Group 2MLPP Target 2MLPP CSS 2MLPP No Answer Ring Duration 2Line Text Label 2External Phone Number Mask 2Maximum Number of Calls 2Busy Trigger 2Visual Message Waiting Indicator Policy 2Ring setting (Phone Idle) 2Ring Setting (Phone Active) 2Caller Name 2Caller Number 2Redirected Number 2Dialed Number 2Line Description 2Alerting Name 2ASCII Alerting Name 2Line Presence Group 2Secondary CSS for Forward All 2Forward on CTI Failure Voice Mail 2Forward on CTI Failure Destination 2Forward on CTI Failure CSS 2Display 2ASCII Display 2ASCII Line Text Label 2AAR Destination Mask 2AAR Voice Mail 2Forward Unregistered Internal Voice Mail 2Forward Unregistered Internal Destination 2Forward Unregistered Internal CSS 2Forward Unregistered External Voice Mail 2Forward Unregistered External Destination 2Forward Unregistered External CSS 2Hold Reversion Ring Duration 2Hold Reversion Notification Interval 2Retain this destination in call forwarding history 2Audible Message Waiting Indicator Policy 2Recording Option 2Recording Profile 2Monitoring Calling Search Space 2Calling Search Space Activation Policy 2Allow Control of Device from CTI 2CPG Audio Alert Setting(Phone Idle) 2CPG Audio Alert Setting(Phone Active) 2Park Monitor Forward No Retrieve Ext Voice Mail 2Park Monitor Forward No Retrieve Ext CSS 2Park Monitor Forward No Retrieve Int CSS 2Park Monitoring Reversion Timer 2Park Monitor Forward No Retrieve Ext Destination 2Park Monitor Forward No Retrieve Int Destination 2Park Monitor Forward No Retrieve Int Voice Mail 2Party Entrance Tone 2Log Missed Calls 2Speed Dial Number 1Speed Dial Label 1Speed Dial Label ASCII 1Service Name 1Subscribed Service Name 1Subscribed Service URL 1Subscribed Service Name ASCII 1SURL Label 1SURL Label ASCII 1SURL Button Index 1Parameter Name 1Parameter Value 1Parameter Name 2Parameter Value 2Parameter Name 3Parameter Value 3
From 9.XDevice NameDescriptionDevice PoolPhone Button TemplateCSSAAR CSSLocationExtension MobilityNetwork LocaleMedia Resource Group ListUser Hold MOH Audio SourceNetwork Hold MOH Audio SourceDevice User LocalePacket Capture ModePacket Capture DurationBuilt in BridgePrivacyRetry Video Call as AudioIgnore Presentation IndicatorsSoftkey TemplateModule 1Module 2Phone Load NameModule 1 Load NameModule 2 Load NameInformationDirectoryMessagesServicesAuthentication ServerProxy ServerIdleIdle TimerMLPP IndicationMLPP PreemptionMLPP DomainDevice TypeUser ID 1Common Phone ProfileOwner User IDAllow CTI Control FlagDevice Presence GroupDevice Security ProfileDevice Subscribe CSSUnattended PortRequire DTMF ReceptionRFC2833 DisabledCertificate OperationAuthentication StringOperation Completes ByDevice ProtocolSecure Shell UserSecure Shell PasswordXMLDial RulesCSS RerouteRerouting Calling Search SpaceDTMF SignallingDefault DTMF CapabilitySIP ProfileMTP Preferred Originating CodecLogout ProfileMTP RequiredDigest UserSignaling PortOutgoing Caller ID PatternCalling Party SelectionCalling Party PresentationDisplay IE DeliveryRedirecting Number IE Delivery OutboundRedirecting Number IE Delivery InboundGatekeeper NameE.164Technology PrefixZoneMotorola WSM ConnectionSubscriber Cellular NumberFollow me only when caller has dialed cellular numDisable Application Dial RulesAAR GroupLogged Into Hunt GroupRemote DeviceDevice Mobility ModeCommon Device ConfigurationMobility User IDDND OptionDND Incoming Call AlertDo Not DisturbJoin Across LinesSingle Button BargeBLF Audible Alert Setting (Phone Idle)BLF Audible Alert Setting (Phone Busy)Calling Party Transformation CSSUse Trusted Relay PointServices ProvisioningMobile Smart Client ProfileOutbound Call RolloverPhone PersonalizationProtected DevicePrimary PhoneGeo LocationAlways Use Prime LineAlways Use Prime Line for Voice MessageHotline DeviceSecure Authentication URLSecure Directory URLSecure Idle URLSecure Information URLSecure Messages URLSecure Services URLSRTP AllowedFeature Control PolicyModule 3Module 3 Load NameDevice Trust ModeAllow presentation sharing using BFCPMobility Identity NameMobility Identity Destination NumberMobility Identity Answer Too Soon TimerMobility Identity Answer Too Late TimerMobility Identity Delay Before Ringing CellMobility Identity Time ZoneMobility Identity Is Mobile PhoneMobility Identity Enable Mobile ConnectMobility Identity Mobility ProfileDirectory Number 1Route Partition 1Voice Mail Profile 1Line CSS 1AAR Group(Line) 1Line User Hold MOH Audio Source 1Line Network Hold MOH Audio Source 1Auto Answer 1Forward All Voice Mail 1Forward All Destination 1Forward All CSS 1Forward Busy Internal Voice Mail 1Forward Busy Internal Destination 1Forward Busy Internal CSS 1Forward Busy External Voice Mail 1Forward Busy External Destination 1Forward Busy External CSS 1Forward No Answer Internal Voice Mail 1Forward No Answer Internal Destination 1Forward No Answer Internal CSS 1Forward No Answer External Voice Mail 1Forward No Answer External Destination 1Forward No Answer External CSS 1Forward No Coverage Internal Voice Mail 1Forward No Coverage Internal Destination 1Forward No Coverage Internal CSS 1Forward No Coverage External Voice Mail 1Forward No Coverage External Destination 1Forward No Coverage External CSS 1Forward No Answer Ring Duration 1Call Pickup Group 1MLPP Target 1MLPP CSS 1MLPP No Answer Ring Duration 1Line Text Label 1External Phone Number Mask 1Maximum Number of Calls 1Busy Trigger 1Visual Message Waiting Indicator Policy 1Ring setting (Phone Idle) 1Ring Setting (Phone Active) 1Caller Name 1Caller Number 1Redirected Number 1Dialed Number 1Line Description 1Alerting Name 1ASCII Alerting Name 1Line Presence Group 1Secondary CSS for Forward All 1Forward on CTI Failure Voice Mail 1Forward on CTI Failure Destination 1Forward on CTI Failure CSS 1Display 1ASCII Display 1ASCII Line Text Label 1AAR Destination Mask 1AAR Voice Mail 1Forward Unregistered Internal Voice Mail 1Forward Unregistered Internal Destination 1Forward Unregistered Internal CSS 1Forward Unregistered External Voice Mail 1Forward Unregistered External Destination 1Forward Unregistered External CSS 1Hold Reversion Ring Duration 1Hold Reversion Notification Interval 1Retain this destination in call forwarding history 1Audible Message Waiting Indicator Policy 1Recording Option 1Recording Profile 1Monitoring Calling Search Space 1Calling Search Space Activation Policy 1Allow Control of Device from CTI 1CPG Audio Alert Setting(Phone Idle) 1CPG Audio Alert Setting(Phone Active) 1Park Monitor Forward No Retrieve Ext Voice Mail 1Park Monitor Forward No Retrieve Ext CSS 1Park Monitor Forward No Retrieve Int CSS 1Park Monitoring Reversion Timer 1Park Monitor Forward No Retrieve Ext Destination 1Park Monitor Forward No Retrieve Int Destination 1Park Monitor Forward No Retrieve Int Voice Mail 1Party Entrance Tone 1Log Missed Calls 1Directory Number 2Route Partition 2Voice Mail Profile 2Line CSS 2AAR Group(Line) 2Line User Hold MOH Audio Source 2Line Network Hold MOH Audio Source 2Auto Answer 2Forward All Voice Mail 2Forward All Destination 2Forward All CSS 2Forward Busy Internal Voice Mail 2Forward Busy Internal Destination 2Forward Busy Internal CSS 2Forward Busy External Voice Mail 2Forward Busy External Destination 2Forward Busy External CSS 2Forward No Answer Internal Voice Mail 2Forward No Answer Internal Destination 2Forward No Answer Internal CSS 2Forward No Answer External Voice Mail 2Forward No Answer External Destination 2Forward No Answer External CSS 2Forward No Coverage Internal Voice Mail 2Forward No Coverage Internal Destination 2Forward No Coverage Internal CSS 2Forward No Coverage External Voice Mail 2Forward No Coverage External Destination 2Forward No Coverage External CSS 2Forward No Answer Ring Duration 2Call Pickup Group 2MLPP Target 2MLPP CSS 2MLPP No Answer Ring Duration 2Line Text Label 2External Phone Number Mask 2Maximum Number of Calls 2Busy Trigger 2Visual Message Waiting Indicator Policy 2Ring setting (Phone Idle) 2Ring Setting (Phone Active) 2Caller Name 2Caller Number 2Redirected Number 2Dialed Number 2Line Description 2Alerting Name 2ASCII Alerting Name 2Line Presence Group 2Secondary CSS for Forward All 2Forward on CTI Failure Voice Mail 2Forward on CTI Failure Destination 2Forward on CTI Failure CSS 2Display 2ASCII Display 2ASCII Line Text Label 2AAR Destination Mask 2AAR Voice Mail 2Forward Unregistered Internal Voice Mail 2Forward Unregistered Internal Destination 2Forward Unregistered Internal CSS 2Forward Unregistered External Voice Mail 2Forward Unregistered External Destination 2Forward Unregistered External CSS 2Hold Reversion Ring Duration 2Hold Reversion Notification Interval 2Retain this destination in call forwarding history 2Audible Message Waiting Indicator Policy 2Recording Option 2Recording Profile 2Monitoring Calling Search Space 2Calling Search Space Activation Policy 2Allow Control of Device from CTI 2CPG Audio Alert Setting(Phone Idle) 2CPG Audio Alert Setting(Phone Active) 2Park Monitor Forward No Retrieve Ext Voice Mail 2Park Monitor Forward No Retrieve Ext CSS 2Park Monitor Forward No Retrieve Int CSS 2Park Monitoring Reversion Timer 2Park Monitor Forward No Retrieve Ext Destination 2Park Monitor Forward No Retrieve Int Destination 2Park Monitor Forward No Retrieve Int Voice Mail 2Party Entrance Tone 2Log Missed Calls 2Speed Dial Number 1Speed Dial Label 1Speed Dial Label ASCII 1Service Name 1Subscribed Service Name 1Subscribed Service URL 1Subscribed Service Name ASCII 1SURL Label 1SURL Label ASCII 1SURL Button Index 1Parameter Name 1Parameter Value 1Parameter Name 2Parameter Value 2Parameter Name 3Parameter Value 3
I have added the excel version below
You can see this field exist in 9.x as well in my verison
Sure here's the comparison:
CUCM 8.6Single Button BargeBLF Audible Alert Setting (Phone Idle)BLF Audible Alert Setting (Phone Busy)Calling Party Transformation CSSUse Trusted Relay PointServices ProvisioningMobile Smart Client Profile
CUCM 9.1Single Button BargeBLF Audible Alert Setting (Phone Idle)BLF Audible Alert Setting (Phone Busy)Use Trusted Relay PointServices ProvisioningMobile Smart Client ProfileOutbound Call Rollover
Oh ya, What's the version your running?   I'm running  "version: 9.1.1.10000-11" ...
Thanks again...
So I goofed I did both exports from 8.6 whoops...
See attached.
I would deleted CP column CP form 8.6  and make sure you have appropiate valuse in for all new fields.
But if you are doing this correctly It should work as it did for me in the past.
Thanks Gregory,
     Ya I tried deleting that 8.6 column and importing it but got an error saying (blank)is not a supported field.  I'm going to try to delete that column in the 8.6 export and try copying and pasting the data into the 9.1 export. Not fun stuff
I would also do a sanity check on your file make sure you don't have an extra , or something that is throwing it off.
I have had users that put ' in the last name and it goofs up only that record.  Your error message is almost stating that the an extra column exist that is labeled blank.
Weird I agree.  Let me know how it goes.
658
