All IP phones cannot register to CM8.6 after upgrade
Hi all,
After upgrade from CM8.5 to CM8.6.1
all IP Phone cannot register to CM8.6 successfully.
and i found the following err message from (7970) one of the IP Phones  log
2928: ERR 04:59:24.616980 JVM: Startup Module Loader|cip.cfg.t:? - Delete of sshUserInfo file failed
2929: ERR 04:59:24.619096 JVM: Startup Module Loader|cip.cfg.t:? - informationUrl is https://10.10.1.10:8443/ccmcip/GetTelecasterHelpText.jsp
2930: ERR 04:59:24.621347 JVM: Startup Module Loader|cip.cfg.t:? - directoriesUrl is https://10.10.1.10:8443/ccmcip/xmldirectory.jsp
2931: ERR 04:59:24.623539 JVM: Startup Module Loader|cip.cfg.t:? - messagesUrl is
2932: ERR 04:59:24.625622 JVM: Startup Module Loader|cip.cfg.t:? - servicesUrl is https://10.10.1.10:8443/ccmcip/getservicesmenu.jsp
2933: ERR 04:59:24.627737 JVM: Startup Module Loader|cip.cfg.t:? - authenticationUrl is https://10.10.1.10:8443/ccmcip/authenticate.jsp
2934: ERR 04:59:24.629793 JVM: Startup Module Loader|cip.cfg.t:? - idleUrl is
2935: ERR 04:59:24.633080 JVM: Startup Module Loader|cip.cfg.t:? - messagesUrl is null
2936: ERR 04:59:24.635258 JVM: Startup Module Loader|cip.cfg.t:? - After set servicesUrl device.settings.config.servicesurl value https://10.10.1.10:8443/ccmcip/getservicesmenu.jsp
2937: ERR 04:59:24.637433 JVM: Startup Module Loader|cip.cfg.t:? - After set info url device.settings.config.informationurl value https://10.10.1.10:8443/ccmcip/GetTelecasterHelpText.jsp
2938: ERR 04:59:24.639551 JVM: Startup Module Loader|cip.cfg.t:? - After set  dir Url device.settings.config.directoriesurl value https://10.10.1.10:8443/ccmcip/xmldirectory.jsp
2939: ERR 04:59:24.641770 JVM: Startup Module Loader|cip.cfg.t:? -  idle Url of null
2940: ERR 04:59:24.643884 JVM: Startup Module Loader|cip.cfg.t:? - After set  sec auth Url device.settings.config.authenticationurl value https://10.10.1.10:8443/ccmcip/authenticate.jsp
2941: ERR 04:59:24.646022 JVM: Startup Module Loader|VendorConfig:? - vendorconfig : setConfigProperties
2942: ERR 04:59:24.648051 JVM: Startup Module Loader|VendorConfig:? -
About to set WebAccess
anybody can help?
Sam
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: All IP phones cannot register to CM8.6 after upgrade
That easy to find out, just go to the licensing report from CCMAdmin and see the status of your licenses, but most likely you're right. It will have to do with either node licenses or SW feature license.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Are the CCM services running??
Those logs have no info of why this is happening.
java
java
thanks for the reply, you're right,the callmanager service isn't started. And even I started it manually. I think the reason could be the feature license issue after upgrade.
Thanks for the quick respond
Sam
java
java
453
