All outbound LD calls default to "local" dial-peer
Hello experts,
This is a new small office VoIP setup utilizing a 2851 Integrated Services router. System is fully configured and working for the most part -- internal and local outbound calls work as well as incoming calls. I have 2 dial-peers for outbound calling that i'm concerned about, one for local, one for long-distance.
All outbound calls are matching the first dial-peer "9.......", even though users specifiy "91..........". I'm not sure why. I have COR's setup, but have double-checked to make sure they're acurate.
Any help would be greately appreciated.
COR's and dial-peer config:
dial-peer cor custom
name internal
name local
name domestic
name international
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-domestic
member internal
member local
member domestic
dial-peer cor list user-international
member internal
member local
member domestic
dial-peer voice 1 pots
description ** T1 PRI pots dial-peer **
destination-pattern 911
port 0/1/0:23
forward-digits all
dial-peer voice 2 pots
destination-pattern 9911
port 0/1/0:23
forward-digits 3
dial-peer voice 3 pots
destination-pattern 9.......
port 0/1/0:23
forward-digits 7
dial-peer voice 4 pots
destination-pattern 91..........
port 0/1/0:23
forward-digits 10
prefix 1
dial-peer voice 5 pots
corlist outgoing call-international
destination-pattern 9011T
port 0/1/0:23
forward-digits all
dial-peer voice 8 pots
incoming called-number .
direct-inward-dial
port 0/1/0:23
dial-peer voice 40 voip
description ** cue voicemail pilot number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 4240
session protocol sipv2
session target ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 41 voip
description ** cue auto attendant number **
destination-pattern 4250
codec g711ulaw
no vad
Additionally, running a "show dialplan number" on a long-distance number shows a match with dial-peer 3 (local). I can't figure out why???
Any help would be greatly appreciated.
Jad
  • IP Telephony
Hall of Fame Super Gold
Re: All outbound LD calls default to "local" dial-peer
Hi, try:
destination-pattern 9[2-9]......
that didn't change much. I'll start dialing a 10-digit long distance number, but the phone stops at 7-digits and starts calling out.
example:
I dial a local number 123-4567 - matches dial-peer 3 and goes through fine.
I dial a long distance number 1-123-456-7890 - it stops at 1123456.
Hi, the example you made should never match DP 3.
Please post output of "show dialplan number 915551234567".
That's what i'm thinking...attached.
Hi, the output indicates that now you have corlist call-domestic for DP 4, please check that the incoming DP or ephone-dn has also corresponding corlist privileges.
yes, both the incoming DP and the ephone-dn are configured with that corlist...
corlist outgoing call-local
port 0/1/0:23
forward-digits 7
corlist outgoing call-domestic
huntstop
no digit-strip
port 0/1/0:23
forward-digits 10
prefix 1
ephone-dn 85 dual-line
number 4285
label 4285
description Test Phone
name Visitor 4285
call-forward busy 4240
call-forward noan 4240 timeout 15
corlist incoming user-domestic
hold-alert 30 originator
corlist "user-domestic" and "call-domestic" are members of the same group...
name internal
name local
name domestic
name international
member internal
member local
member domestic
member internal
member internal
member local
member internal
member local
member domestic
member internal
member local
member domestic
I found the issue - the FXO dial-peers were taking presedence. I removed them for now and all is working well.
Thanks for you help!!
FYI- Might help someone else....
I ran into the same problem during a recent install of CME4.2. Cisco TAC came up with the following solution:
The reason for the problem is due to the way CME accepts dialed digits. As it accepts digits one by one rather than all at once it will match the 7 digit dial-peer first when you want it to match the 10 digit dial-peer.
This can be overcome by adding a T to the end of the 7 digit dial-peer. This makes the dial-peer wait the length of the inter-digit timeout for more digits to come in. If the inter-digit timeout expires then the 7 digit dial-peer is chosen. If more digits are entered then the next best dial-peer will be chosen (the 10 digit dial-peer assuming 10 digits are entered).
Below is a sample configuration
dial-peer voice XX pots
description LOCAL
destination-pattern 91.......T
port x/x/x
description LONG DISTANCE
port x/x/x
321
