Allocating DID's in CME
Dear All,
I have both Cisco & Non-Cisco IP Phones which are reigistered in my voice gateway. Now i have got ISDN with DID's. How can i allocate some DN with DID number in order to call in both ways ( each extension 5000 calls outside, its DID should go outside like 8995000, and calling on same DID 8995000 should come to 5000).
Rest extension should call using main number. How is it possible in CME environment? Thanks
  • IP Telephony
1 ACCEPTED SOLUTION
Re: Allocating DID's in CME
For you clarification do this:
voice translation-rule 101
   rule 1 /5010/ /8994750/
   rule 2 /5012/ 8994751/
   rule 3 /5013/ 8994752/
voice translation-rule 102
   rule 1 /8994750/ 5010/
   rule 2 /8994751/ 5012/
   rule 3 /8994752/ 5013/
voice translation-profile ISDN-Out
   translate calling 101
voice translation-profile ISDN-IN
   translate called 102
Dial-peer voice xyz pots
   translation-profile outgoing ISDN-Out
   translation-profile incoming ISND-IN
or
voice-port 0/0/0:D
Explanation:
When call comes from outside to gateway, suppose called number or dialed number is 8994750, the translation-profile ISDN-IN will matched and the callled number i.e. 8994750 is replaced with 5010 and call will be routed to phone extension 5010.
When extension 5010 make an outgoing calls for a PSTN destination number (ex xxxxxxxxx), the translation-profile ISDN-Out will be matched and extension 5010 is replace with 8994750 and it is displayed in the PSTN destination phone.
to verfiy:
#test voice translation-rule 101 5010
#test voice translation-rule 102 8994750
you will get the output of orginal number and translated number.
Selvarathnam
Hall of Fame Super Gold
Using voice translation profile and rules.
Where can we use these translation profiles. In my case, I have fxs port which is registered on another gateway which is connected to this gateway which has isdn line and did.
On voice-port.
Hi Omerpal,
The FXS port is connected to another gateway say gateway "A" and the gateway "A" is connected to this gateway say gateway "B" am I right?
If so, than you need to apply the rules in Gateway "B" where the ISDN is terminated, on the VoIP dial-peer which pointing the Gateway "A".
Dear Selva,
How can we define translation rules & profile in this typical scanerio? Thanks
Omer, can you share your configuration along with rough topology description.
8994999.....DID starting from 700 to 999
Extensions starting from 5000 to 5020
Matrix Gateway is connected with Cisco 2951 via SIP trunk. I didnt configure router too much for voice but only configured some dial-peer as below:
Matrix Gateway (192.168.99.11) has 4 port FXS and 4 port GSM. First FXS port has 5010 extension
Cisco Gateway has one IP Phone and CIPC. IP Phone has 5012 and CIPC has 5013 (CME)
5012 & 5013 can call 5010 via SIP Trunk using below dial-peer
dial-peer voice 600 voip
destination-pattern 5010
session protocol sipv2
session target ipv4:192.168.99.11
dtmf-relay sip-notify
codec g711alaw
no vad
And 5010 (FXS port) is also configured to reach 5012 & 5013.
Now I have some outbound dialpeers to call on mobile, landline and international. Right now when 5010 (on Matrix Gateway) and 5012 & 5013 DN call outside then receiver get main number which is 8994999 (mentioned above). Bit i want 5010 (on Matrix Gateway) and 5012 & 5013 DN when call outside they should get different number like 8994750, 8994751 and 8994752.
I didnt configure translation rule and profile but ISDN is configured.
Create, translation rule, assign it with translation profile and than apply the profile under outgoing dial-peer or ISDN voice-port.
For outgoing/incoming calls replace calling/called numbers
Global configuration mode.
voice translation-profile ISDN-Calls
   translation-profile outgoing ISDN-Calls
or
voice-port 0/0/0:D
Explanation:
Rule 101 replace the 5010 with 8994750 when making any outgoing calls, and displayed as 8994750 in remote phones and so on.
Rule 102 replace the 8994750 with 5010, when any caller from outside call 8994750 it will reach to 5010 extension and so on.
It is just a simple digit manipulation configuration. The other extensions calls will display as your main number i.e. 8994999.
if you want to land all main number incoming calls to 5000 extension, add one rule in 102 as rule 4 /8994999/ /5000/
Thanks Selva, i didnt put the command so far. Anyways, i just need some explanation about the following. Thanks
What will below profile do ? (especially when call comes to gateway from outside)
Why have you used outgoing ? You didnt you use incoming in followng (what will happen if you se incoming)
1238
