Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Allow 4 extensions for incoming PSTN line.
Is it possible to have 4 extensions ring at the same time when someone calls a specific pstn line. I need to know how to do this. Currently we have it setup so only one extension rings at a time.
Thanks.
1 ACCEPTED SOLUTION
Re: Allow 4 extensions for incoming PSTN line.
Refer to this link for paralell blast option . If this help
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1145800
Br, Nadeem Please rate all useful post.
Bronze
This can be done using a hunt pilot and line group with broadcast .  The config depends on what system you are running. (CUCM/CME)
You can also just add a new line containing the same DN to all the phones that you wish to ring.
Gareth
I am currently running CME 8.4 on a cisco 3800 router. Do you have a link where I could say find an example of how this is done.
Thanks.
Thanks a lot for reply Nadeem its exactly what I was looking for.
104
