Community Member
Allowing certain numbers to be dialed
At present we block 0800 numbers etc depending on users requirements. We however have a supplier that is using an 0843 number for their call centre and rather than open up 0800 numbers for everyone in the business is there a way of allowing the 0843 number to be dialed? Can I set up a partition for this or a calling search space??
1 ACCEPTED SOLUTION
Re: Allowing certain numbers to be dialed
I'll assume CUCM 7.1(2)
Configure a route pattern with the exact phone number if you know it.
Otherwise configure a route pattern with 0843. If you're blocking 08XX the calls will go thru as well.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1 REPLY
java
java
112
