Alphanumeric Usier ID for Extension mobility CME
Hi Can any one tell me if we can have CME to use only Numeric user ids for Extension mobility.
Sine in our Org. the users uses their employee id (numeric) as their login id, it is difficult to key in the user id since CME by default supports Alpha numberic enrties.
For example a user with user id 6504161 need to login, he need to press the button 6 on his IP phone four times to key in digit 6, where as in CCM we can  block the use of Alpha numeric user id from the service parameters. Similarly is there a way in CME to use only numeric user ids ???
Bejoy Thomas
Hall of Fame Super Gold
Re: Alphanumeric Usier ID for Extension mobility CME
If you search the forum, this has been discussed already.
Numeric only is not supported, and there is no word by Cisco if that is ever going to change.
Thanks Paolo...
360
