Alternate extension in CUE
Hi Guys,
There are some Unbelievably experienced people here. will like you to help me with this one.
Can i set up alternate extension on CUE like i do on unity? i mean i want call diverted from an alternate number to go into the voice mail (mailbox)of the main number. is this possible in CUE? if so, how do i do this?
thanks.
Hall of Fame Super Red
Re: Alternate extension in CUE
Hi Akin,
This is possible in CUE as well :) Have a look;
Q. How do you associate more than one Cisco Unified Communications Manager Express extension to a Cisco Unity Express voice mailbox?
A. It is possible to have up to two numbers in the same Cisco Unity Express (CUE) User profile. Configure the first number as the Cisco Unity Express User Primary Extension, and the other number as the Primary E.164 number. However, only two Cisco Unified Communications Manager Express extensions are allowed to share the same mailbox in the Cisco Unity Express voicemail.
From this good Q&A doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_qanda_item09186a0080875c6f.shtml#q12
Place one ext in the primary ext field, and the other in the E.164 field
phonenumber - Specifies a number or extension for this user. No spaces or dashes are allowed.
phonenumberE164 - Specifies a telephone number with area code for this user. No spaces or dashes are allowed.
Example:
se-10-0-0-0(config)# username user3 create
se-10-0-0-0(config)# username user3 phonenumber 50180
se-10-0-0-0(config)# username user3 phonenumberE164 13335550180
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_administration_guide_chapter09186a00803ef7a7.html
Hope this helps!
Rob
Silver
I have CallManager, not CCM, and I have a need for multiple alternate extensions.
Is there a way to do this with general delivery mailboxes and the groups associated with them?
HI,
i tried this and it is working internally.
when i dial 690 CUE pilot number, i reach the voice mail, i press * and than enter user id and password.
from outside when i can call 690, the voice mail answers saying this mailbox have no extension associated to it, wait while i transfer your call.
i went further with my search, in fact i called the AA locally and than called the 690 and i got the same results, i guess i need the experts ;-)
P.S: i beleive the voice see that the call is coming from the AA not from the original number (either internal or external)
Good day
1658
