Alternatives to preventing an IP Phone from creating a conference
Hi All,
Is there another way to prevent an IP Phone from creating a conference call besides creating a Media Resource Group without a Conference Bridge Resource for that phone?
2 ACCEPTED SOLUTIONS
Silver
Re: Alternatives to preventing an IP Phone from creating a confe
Set max # of calls to 1 on the DN.
Pls rate if helpful!
-mike
You can remove the Conference softkey. In the CCMAdmin webpage go to Device --> Phone, check the Softkey tempalte that the phone is using, then go to Device --> Device Settings --> Softkey Template, select the one that the phone is using and then on the upper right side select Configure Softkey layout. Just remove the Conference softkey from the connected state and other state that you need.
//Jorge
Silver
-mike
//Jorge
114
