Am I OK for voice if I am running ENTERPRISE BASIC IOS ?
news2010a
Level 3
Level 3
If I want to run VoIP on my 2610 routers (running XM image c2600-j1s3-mz.123-16.bin) do you know whether I can setup the FXO voice card and make this work if I have the ENTERPRISE BASIC image ?
Someone told me that I should run the IP Plus IOS. However, the Cisco Feature software navigator and the (config)#? commands below seem to indicate that the ENTERPRISE BASIC I am running does support voice. Please confirm whether I will be OK with the ENTERPRISE BASIC image, including when installing the appropriate voice cards onto my C2610.
Thanks much !
RouterB(config)#voice ?
call enable to send alert instead of progress.
class Control parameters class
disc-pi-incoming-on disconn with PI from incoming leg is maintained
dnis-map Create or add to a dnis-map
dsp DSP functions
enum-match-table enum match table entry
hpi Host port interface
hunt Dialpeer hunt conditions.
rtp enable to open RTP in both directions.
service Global packet telephony service commands
source-group Source Group configuration commands
translation-profile Translation profile configuration commands
translation-rule Translation Rule configuration commands
vad-time Voice activity detection hangover period
Outputs from Software Advisor
pbarman
Level 5
Level 5
Software Advisor at this link would be your best tool to answer this.
http://www.cisco.com/kobayashi/support/tac/tools.shtml
I checked that out and yes Enterprise Basic would support your FXO card but that depends on the FXO card model.
VIC-2FXO ---> 12.3.16 Enterprise Basic would support. This is the IOS you mentioned above.
For other models, like VIC2-2FXO or VIC2-4FXO, you will need Enterprise Base feature set and a T train.
Please see attached outputs from Software Advisor.
