An internal extension can be dialed and the call will be connected internally
Hi, I have a user request to have a number which can be called by our users from external (mobile phone), after the system answers the number of an internal extension can be dialed and the call will be connected internally.
Important that the number cannot be abused the it must be restricted to dial internal numbers starting with 7 and exact 7 digits.
Can somebody help me to find a solution?
Start by mentioning what you
Start by mentioning what you have available to work with, what products and versions?
java
if this helps, please rate
www.cisco.com/go/pdi
cisco unity connection
cisco unity connection administration (9.1.1.10000-32)
and cisco call manager (9.1.2.11900-12)
Send calls directly to CUC
Send calls directly to CUC for the transfer and configure restriction tables and CSS in CUCM to avoid toll fraud.
java
50
