Community Member
Analog Conference phone on H.323 Gateway
Hello again guys,
I have an analog conference phone using an FXS port on a H.323 gateway, the analog phone is not capable of 3 way calling right now.
Before changing the gateway to MGCP I wanted to ask if its possible to have 3 way calling using an FXS line on an H.323 gateway. The number being used is currently set up as a route pattern in CUCM 7.1.
2 ACCEPTED SOLUTIONS
Bronze
Re: Analog Conference phone on H.323 Gateway
You will need to configure the dial-peer to be controlled by SCCP using stcapp. This allows the port to utilise the DSP chips on the gateway so that you can have 3-way conferencing.
Example config:
stcapp ccm-group 1
stcapp
dial-peer voice 22 pots
description **Dial Peer for Main Conference Phone**
service stcapp
port 2/0/2
Cheers,
Phil
VIP Super Bronze
For stcapp, you need a minimum of 12.4(15)T
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
Bronze
Example config:
stcapp ccm-group 1
stcapp
service stcapp
port 2/0/2
Cheers,
Phil
Community Member
Phil, thanks for the answer. I was unable to start the stcapp service in my gateway.
I'm using a 2821 with IOS 12.4(13r)T running in it. I did get the SCCP service started, but stcapp was not available at the CLI.
What am I doing wrong? IOS perhaps?
Thank you in advance.
Coconino
VIP Super Bronze
Community Member
Thank you all for the answer, its been very helpful.
Coconino
466
