Analog DID and 2901 calls fail.
I have a site that was recently converted from a TDM system using analog DID's. A Vwic 4 fxs/did was installed. The ports were set up as did, wink start. Calls do not seem to pass the digits across the dial peers or on the debuts. There is a dial peer with incoming number.
Normally with an analog did port you can use a test set to test dial numbers; however that fails.
Debugs show the call hitting the port, but flexdsprm-3-TDM connect fails to connect voice port to ESP channel.
1 REPLY
Re: Analog DID and 2901 calls fail.
Here is an update to the issue:
To clear the DSP errors, a reload of the gateway was preformed. This did not clear the issue. The FXS card was replaced, and the gateway reloaded.
There were bent pins on the trunk demarc causing a short on one DID trunk. The ports were removed and added back.
The issue is cleared and working now.
401
