Community Member
Analog line (FXO) Incoming calls getting connected after 3 rings
     HI,
we are having 4 Analog line (FXO)...Every time when callers call the number they hear 3 rings & after that call frwds to AA or any extension.
In show voice port summary, we can see that voice port is getting connect at the first ring but after 3 rings only phone rings.
here is the o/p of voice port.
Foreign Exchange Office 0/0/0 Slot is 0, Sub-unit is 0, Port is 0
Type of VoicePort is FXO
Operation State is DORMANT
Administrative State is UP
No Interface Down Failure
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is plar
Connection Number is 250
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Power Denial Disconnect Time Out is set to 1000 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for AE
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name None, Station number None
Caller ID Info Follows:
Standard BELLCORE
Caller ID is received after 1 ring(s)
Translation profile (Incoming): INCOMING_CallerID_PROFILE
Translation profile (Outgoing):
lpcor (Incoming):
lpcor (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Battery-Reversal is enabled
Number Of Rings is set to 1
Supervisory Disconnect is signal
Answer Supervision is inactive
Hook Status is On Hook
Ring Detect Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Dial Out Type is dtmf
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Pulse Rate Timing is set to 10 pulses/second
InterDigit Pulse Duration Timing is set to 750 ms
Percent Break of Pulse is 65 percent
GuardOut timer is 2000 ms
Minimum ring duration timer is 125 ms
Hookflash-in Timing is set to 600 ms
Hookflash-out Timing is set to 400 ms
Supervisory Disconnect Timing (loopStart only) is set to 350 ms
OPX Ring Wait Timing is set to 6000 ms
Secondary dialtone is disabled
Hall of Fame Super Silver
Re: Analog line (FXO) Incoming calls getting connected after 3 r
Post your config and debug vpm signal.
Community Member
hostname VGUAE001
no aaa new-model
clock timezone UAE 4 0
ip cef
ip domain name yourdomain.com
no ipv6 cef
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
translation-profile outgoing PROFILE_ALL_FXO
voice-card 0
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
voice class cause-code 1
no-circuit
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 3265
rule 1 // /9\1/
voice translation-profile INCOMING_CallerID_PROFILE
translate calling 50
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
license udi pid CISCO2901/K9 sn FCZ173992Z8
hw-module pvdm 0/0
hw-module pvdm 0/1
username cisco privilege 15 secret 4 opjnnkXqCr4kCOa9DuALcNpBOMetBAc/usnpSWADsCI
username godiva privilege 15 secret 4 cH8b8z.ioYu/pMv/AKuEcBd/f6g9v/vm/s3aXeqUAd6
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 192.168.31.2 255.255.255.0
ip helper-address 192.168.31.11
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.31.2
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip http path flash:
ip route 0.0.0.0 0.0.0.0 192.168.31.1
control-plane
voice-port 0/0/0
trunk-group ALL_FXO 64
translation-profile incoming INCOMING_CallerID_PROFILE
groundstart auto-tip
cptone AE
connection plar opx 222
caller-id enable
voice-port 0/0/1
cptone AE
caller-id enable
voice-port 0/0/2
cptone AE
caller-id enable
voice-port 0/0/3
cptone AE
connection plar opx 250
caller-id enable
mgcp profile default
dial-peer voice 2000 voip
destination-pattern 2..
session target ipv4:192.168.31.11
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 10 pots
trunkgroup ALL_FXO
description **CCA*UAE*Fire**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 997
forward-digits all
no sip-register
dial-peer voice 11 pots
trunkgroup ALL_FXO
description **CCA*UAE*International Numbers**
preference 5
destination-pattern 900T
forward-digits all
no sip-register
dial-peer voice 12 pots
trunkgroup ALL_FXO
description **CCA*UAE*Eitisalat**
preference 5
destination-pattern 9101
forward-digits all
no sip-register
dial-peer voice 13 pots
trunkgroup ALL_FXO
description **CCA*UAE*Water or electrical emergencies**
preference 5
destination-pattern 971
forward-digits all
no sip-register
dial-peer voice 14 pots
trunkgroup ALL_FXO
description **CCA*UAE*Police and emergencies**
preference 5
destination-pattern 999
forward-digits all
no sip-register
dial-peer voice 15 pots
trunkgroup ALL_FXO
description **CCA*UAE*National area codes**
preference 5
destination-pattern 9[1-579].......
forward-digits all
no sip-register
dial-peer voice 16 pots
trunkgroup ALL_FXO
description **CCA*UAE*Mobile Numbers**
preference 5
destination-pattern 90[5-6][0-7].......
forward-digits all
no sip-register
dial-peer voice 17 pots
trunkgroup ALL_FXO
description **CCA*UAE*toll-free**
preference 5
destination-pattern 9[2-9]00T
forward-digits all
no sip-register
dial-peer voice 18 pots
trunkgroup ALL_FXO
description **CCA*UAE*Fixed Line Numbers**
preference 5
destination-pattern 9[2-8]T
forward-digits all
no sip-register
dial-peer voice 19 pots
trunkgroup ALL_FXO
description **CCA*UAE*808**
preference 5
destination-pattern 9808T
forward-digits all
  no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/0/0
dial-peer voice 51 pots
port 0/0/1
dial-peer voice 52 pots
port 0/0/2
dial-peer voice 53 pots
port 0/0/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/0/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/0/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/0/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/0/3
no sip-register
Debug vpm signal:
Nov 23 19:31:31.556: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Nov 23 19:31:31.556: htsp_timer - 125 msec
Nov 23 19:31:31.684: htsp_process_event: [0/0/0, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Nov 23 19:31:31.684: htsp_timer - 10000 msec
Nov 23 19:31:31.684: htsp_timer3 - 5600 msec
Nov 23 19:31:31.684: [0/0/0] htsp_start_caller_id_rx:Mode BELLCORE. Alerting 0x1
Nov 23 19:31:31.684: htsp_start_caller_id_rx create dsp_stream_manager
Nov 23 19:31:31.684: [0/0/0] htsp_dsm_create_success  returns 1
Nov 23 19:31:33.604: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
Nov 23 19:31:33.604: fxols_ringing_not
Nov 23 19:31:33.604: htsp_timer_stop
Nov 23 19:31:33.604: htsp_timer - 10000 msec
Nov 23 19:31:37.284: htsp_process_event: [0/0/0, FXOLS_RINGING, E_HTSP_EVENT_TIMER3]fxols_snoop_clid_stop
Nov 23 19:31:37.284: htsp_timer_stop3
Nov 23 19:31:37.516: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0000]
Nov 23 19:31:39.604: htsp_process_event: [0/0/0, FXOLS_RINGING, E_DSP_SIG_0100]
Nov 23 19:31:39.604: fxols_ringing_not
Nov 23 19:31:39.604: htsp_timer_stop
Nov 23 19:31:39.604: htsp_timer_stop3
Nov 23 19:31:39.604: [0/0/0] htsp_stop_caller_id_rx. message length 0htsp_setup_ind
Nov 23 19:31:39.604: [0/0/0] get_fxo_caller_id:Caller ID receive failed.  parseCallerIDString:no data.
Nov 23 19:31:39.604: [0/0/0] get_local_station_id calling num= calling name= calling time=11/23 23:31  orig called=
Nov 23 19:31:39.604: //-1/B583C95F8093/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=250
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Nov 23 19:31:39.604: //-1/B583C95F8093/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3CE27724, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=250(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=50, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Nov 23 19:31:39.604: //-1/B583C95F8093/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Nov 23 19:31:39.604: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 19:31:39.604: :cc_get_feature_vsa malloc success
Nov 23 19:31:39.604:  cc_get_feature_vsa count is 1
Nov 23 19:31:39.604: :FEATURE_VSA attributes are: feature_name:0,feature_time:1025218944,feature_id:83
Nov 23 19:31:39.604: //83/B583C95F8093/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=250(TON=Unknown, NPI=Unknown))
Nov 23 19:31:39.608: [0/0/0] htsp_dsm_close_done
Nov 23 19:31:39.608: htsp_process_event: [0/0/0, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Nov 23 19:31:39.608: fxols_wait_setup_ack:
Nov 23 19:31:39.608: [0/0/0] set signal state = 0xC timestamp = 0fxols_check_auto_call
Nov 23 19:31:39.608: //83/B583C95F8093/CCAPI/cc_process_call_setup_ind:
   Event=0x22ACD828
Nov 23 19:31:39.608: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 250
Nov 23 19:31:39.608: //83/B583C95F8093/CCAPI/ccCallSetContext:
   Context=0x230F9C10
   >>>>CCAPI handed cid 83 with tag 50 to app "_ManagedAppProcess_Default"
Nov 23 19:31:39.608: //83/B583C95F8093/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
Nov 23 19:31:39.608: //83/B583C95F8093/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=FALSE, Mode=0,
   Outgoing Dial-peer=2000, Params=0x230FB0D0, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Nov 23 19:31:39.608: //83/B583C95F8093/CCAPI/ccCheckClipClir:
   Destination Pattern=2.., Called Number=250, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=B583C95F-53AC-11E3-8093-C8EEBDE4256A, Outgoing Dial-peer=2000
Nov 23 19:31:39.612: //83/B583C95F8093/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=250
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
Nov 23 19:31:39.612: //83/B583C95F8093/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x22847B14, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=250(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2000, Call Count On=FALSE,
   Source Trkgrp Route Label=ALL_FXO, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
Nov 23 19:31:39.612: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Nov 23 19:31:39.612: :cc_get_feature_vsa malloc success
Nov 23 19:31:39.612:  cc_get_feature_vsa count is 2
Nov 23 19:31:39.612: :FEATURE_VSA attributes are: feature_name:0,feature_time:1025218720,feature_id:84
Nov 23 19:31:39.612: //84/B583C95F8093/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
Nov 23 19:31:39.612: //84/B583C95F8093/CCAPI/ccCallSetContext:
   Context=0x230FB080
Nov 23 19:31:39.612: //83/B583C95F8093/CCAPI/ccSaveDialpeerTag:
Nov 23 19:31:39.612: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_proc
Nov 23 19:31:39.612: htsp_timer - 120000 msec
Nov 23 19:31:39.612: //84/B583C95F8093/CCAPI/ccGetMediaClassTag:
   media class tag 0
Nov 23 19:31:39.612: //84/B583C95F8093/CCAPI/ccSetMediaclassIp2ipTags:
   media class tags set: NR 0, ASP 0
Nov 23 19:31:39.612: //83/B583C95F8093/CCAPI/ccSetMediaclassIp2ipTags:
Nov 23 19:31:39.612: //84/B583C95F8093/CCAPI/ccGet_xc_nr_asp_info:
   media class tags: NR 0, ASP 0
Nov 23 19:31:39.612: //83/B583C95F8093/CCAPI/ccGet_xc_nr_asp_info:
Nov 23 19:31:39.620: //84/B583C95F8093/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
Nov 23 19:31:39.620: //84/B583C95F8093/CCAPI/cc_api_call_proceeding:
   Interface=0x22847B14, Progress Indication=NULL(0)
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_set_called_ccm_detected:
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_call_alert:
   Interface=0x22847B14, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Nov 23 19:31:39.628: //83/B583C95F8093/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)htsp_alert_notify
Nov 23 19:31:39.628: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_ALERT]fxols_offhook_alert
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x22847B14, Call Id=84
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
Nov 23 19:31:39.628: //84/B583C95F8093/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
Nov 23 19:31:39.628: //83/B583C95F8093/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=83htsp_call_service_msghtsp_call_service_msg not EFXS (2)
Nov 23 19:31:39.672: //84/B583C95F8093/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/cc_api_call_connected:
   Interface=0x22847B14, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/cc_api_set_called_ccm_detected:
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x22847B14, Call Id=84
Nov 23 19:31:39.700: //83/B583C95F8093/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=83
Nov 23 19:31:39.700: //83/B583C95F8093/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID1=0x53, gcid=B583C95F-53AC11E3-8093C8EE-BDE4256A, tag=0x0)
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/ccConferenceCreate:
   (confID=0xFFFFFFFF, callID2=0x54, gcid=B583C95F-53AC11E3-8093C8EE-BDE4256A, tag=0x0)
   Conference Id=0xFFFFFFFF, Call Id1=83, Call Id2=84, Tag=0x0
Nov 23 19:31:39.700: htsp_call_bridged invoked
Nov 23 19:31:39.700: //83/B583C95F8093/CCAPI/cc_api_bridge_done:
   Conference Id=0x21, Source Interface=0x3CE27724, Source Call Id=83,
   Destination Call Id=84, Disposition=0x0, Tag=0xFFFFFFFF
Nov 23 19:31:39.700: //84/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Nov 23 19:31:39.700: cc_api_get_xcode_stream : 4819
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/cc_api_bridge_done:
   Conference Id=0x21, Source Interface=0x22847B14, Source Call Id=84,
   Destination Call Id=83, Disposition=0x0, Tag=0x0
Nov 23 19:31:39.700: //83/B583C95F8093/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x21, Destination Call Id=84)
   Call Entry(Conference Id=0x21, Destination Call Id=83)
Nov 23 19:31:39.700: confID:0x21; callEntry1 callID1:0x53, type:6; callEntry2 callID2:0x54, type:1
Nov 23 19:31:39.700: //83/B583C95F8093/CCAPI/cc_api_caps_ind:
   Destination Interface=0x22847B14, Destination Call Id=84, Source Call Id=83,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Nov 23 19:31:39.700: //84/B583C95F8093/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
Nov 23 19:31:39.704: //84/B583C95F8093/CCAPI/cc_api_get_ccm_detected:
Nov 23 19:31:39.704: //83/B583C95F8093/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=83htsp_call_service_msghtsp_call_service_msg not EFXS (2)
Nov 23 19:31:39.704: //83/B583C95F8093/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x21, Call Id1=83, Call Id2=84
Nov 23 19:31:39.704: //84/B583C95F8093/CCAPI/cc_api_caps_ind:
   Destination Interface=0x3CE27724, Destination Call Id=83, Source Call Id=84,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
Nov 23 19:31:39.704: //84/B583C95F8093/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9438)
Nov 23 19:31:39.704: //83/B583C95F8093/CCAPI/cc_api_caps_ack:
Nov 23 19:31:39.704: //83/B583C95F8093/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
   Call Entry(Connected=TRUE, Responsed=TRUE)
Nov 23 19:31:39.704: htsp_process_event: [0/0/0, FXOLS_PROCEEDING, E_HTSP_CONNECT]fxols_offhook_connect
Nov 23 19:31:39.704: htsp_timer_stop
Nov 23 19:31:39.704: //83/B583C95F8093/CCAPI/cc_api_voice_mode_event:
   Call Id=83
   Call Entry(Context=0x230F9C10)
Nov 23 19:31:39.704: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_VOICE_CUT_THROUGH]fxols_connect_proc_voice
Nov 23 19:31:39.932: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_DSP_SIG_0110]fxols_rvs_battery
Nov 23 19:31:39.932: htsp_timer_stop2
Nov 23 19:31:48.860: //84/B583C95F8093/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x22847B14, Call Id=84
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
Nov 23 19:31:48.860: //83/B583C95F8093/CCAPI/ccConferenceDestroy:
   Conference Id=0x21, Tag=0x0
Nov 23 19:31:48.860: confID:0x21; callEntry1 callID1:0x53, type:6; callEntry2 callID2:0x54, type:1
Nov 23 19:31:48.860: //83/B583C95F8093/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=84, Disposition=0x0, Tag=0x0
Nov 23 19:31:48.860: //84/B583C95F8093/CCAPI/cc_api_bridge_drop_done:
Nov 23 19:31:48.860: //83/B583C95F8093/CCAPI/cc_generic_bridge_done:
Nov 23 19:31:48.864: //83/B583C95F8093/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Nov 23 19:31:48.864: //83/B583C95F8093/CCAPI/cc_api_get_transfer_info:
   Transfer Number=NULL
Nov 23 19:31:48.864: //84/B583C95F8093/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
Nov 23 19:31:48.864: //84/B583C95F8093/CCAPI/cc_api_get_transfer_info:
Nov 23 19:31:48.864: htsp_timer_stop3
Nov 23 19:31:48.872: //84/B583C95F8093/CCAPI/cc_api_get_transfer_info:
Nov 23 19:31:48.872: //84/B583C95F8093/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x22847B14, Tag=0x0, Call Id=84,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
Nov 23 19:31:48.876: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 19:31:48.876: :cc_free_feature_vsa freeing 3D1B9898
Nov 23 19:31:48.876:  vsacount in free is 1
Nov 23 19:31:48.884: htsp_process_event: [0/0/0, FXOLS_CONNECT, E_HTSP_RELEASE_REQ]fxols_offhook_release
Nov 23 19:31:48.884: htsp_timer_stop
Nov 23 19:31:48.884: htsp_timer_stop2
Nov 23 19:31:48.884: htsp_timer_stop3
Nov 23 19:31:48.884: [0/0/0] set signal state = 0x4 timestamp = 0
Nov 23 19:31:48.884: htsp_timer - 2000 msec
Nov 23 19:31:48.884: //83/B583C95F8093/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3CE27724, Tag=0x0, Call Id=83,
Nov 23 19:31:48.884: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Nov 23 19:31:48.884: :cc_free_feature_vsa freeing 3D1B9978
Nov 23 19:31:48.884:  vsacount in free is 0
Nov 23 19:31:49.156: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_DSP_SIG_0110]
Nov 23 19:31:50.884: htsp_process_event: [0/0/0, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Nov 23 19:31:50.884: htsp_process_event: [0/0/0, FXOLS_ONHOOK, E_DSP_SIG_0100]
Re:Analog line (FXO) Incoming calls getting connected after 3 ri
Do you by any chance have the "caller-id enable" command configured. This issue can occur, if you configure a port with caller-id and the line is not provisioned for caller-id from the carrier.
Yosh
Sent from Cisco Technical Support Android App
HTH Regards, Yosh
Community Member
Thanks Yahsiel,
caller-id is not activated on the site, when i removed the caller-id from the port, its start working properly.
Now my second problem..
when call is coming on voice-port 0/0/0 port, call gets frwd to call-handler (Unity-Connection) Auto-attendent. and port remains off-hook.
when i try to call again..voice-port 0/0/1 shows ring-in state..but its not forwarding to AA. it just keep ringing.
I know this is not the best option but have you tried reloading the GW?
Yosh
HTH Regards, Yosh
Community Member
hi Yosh,
I tried reloading the router..but same prob.
have u checked my above router configuration?
is this a prob with fxo, frequency & cadance?
Community Member
When i am shuting down the first fxo port..call is not going to second port..caller just hear the ring.
527
