Analog Lines & SIP Trunk
Hello all,
I am having 6 analog lines terminating on my CME 9.1 at branch.
I have SIP Trunk between the same branch CME & HQ having CUCM 4.1.
I have configured translation rule to divert call coming from Analog Line to an extension = 9033 (configured for IVR at CUCM in HQ)
so the call route is Call coming in on CME from Analog Line ------> on CME translation rule, & forwarding to extension 9033 through SIP Trunk
following is the configuration :
voice translation-rule 2
rule 1 /77335508/ /9033/
voice translation-profile 2
translate called 2
voice-port 0/2/1
translation-profile incoming 2
supervisory disconnect dualtone mid-call
supervisory dualtone-detect-params 1
timeouts call-disconnect 5
timeouts wait-release 5
connection plar opx 9033
caller-id enable
dial-peer voice 9033 voip
corlist outgoing call-national
destination-pattern 9033
session protocol sipv2
session target ipv4:192.168.0.10
voice-class codec 1
voice-class h323 1
dtmf-relay rtp-nte
no vad
When I can call internally to extension 9033, it plays IVR prompt then it transfer to Agent (which is expected behaviour) but if i call from my mobile to 77335508 some times it hit 9033 & i hear the prompt then transfer to the agent but most of the time it forwards to some voice msging system & i dont know from where this prompt is playing.
I shutdown dial-peer voice 9033 + CUE dial-peer & tried call on 77335508 still the same prompt plays. If i disconnect the analog line from CME & connect through analog phone it does not forward to any prompt & the analog phone rings.
One this i just remembered that i updated my CME from 8.6 to 9.1 & it worked on 8.6 version couple of times.
Is there any compatibility or design issue with receiving call in analog lines & then forwarding to SIP Trunk, is this right design ?
can any body suggest how to trace the incoming & outgoing calls in analog connectivity ? or what are the debug commands ?
I just noticed that my fxo port does not off-hook if i drop the call from my mobile while hearing the IVR prompt (configured at HQ CUCM 4.1) & as soon as the port remains off-hook the telco provider plays msg prompt
Any suggestion as per updated config :
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/1.192
  bind media source-interface GigabitEthernet0/1.192
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
codec preference 4 g729br8
voice class h323 1
  h225 timeout tcp establish 3
  h225 timeout setup 3
voice class dualtone-detect-params 1
freq-max-deviation 20
freq-max-delay 20
cadence-variation 20
voice class custom-cptone AR-custom
dualtone disconnect
  frequency 416 416
  cadence 400 320 240 520
voice-port 0/2/1
supervisory answer dualtone sensitivity high
supervisory custom-cptone AR-custom
no battery-reversal
no vad
no comfort-noise
description **** Voice Port for Etisal IVR ****
caller-id enable
1535
