Community Member
Analog phone ringing issue on FXS VG224 MGCP port.
Hi All,
I am having issue with analog phones connected to my VG224 MGCP gateway. The phone is not ringing when we called the analog phone, but can hear the ring back to calling people. Out going call is Ok, but there is some problem with caller ID.
I have attached the running configuration and debug vpm signal.
Kindly help
Thanks.
when you enter 'show voice
when you enter 'show voice port summary' multiple times during a test call, do you see the port status is changing from on hook to off hook, ringing, etc...?
//Suresh Please rate all the useful posts.
Community Member
Yes I can see the difference
Yes I can see the difference in these values.
Operation State is UP
Currently processing Voice
Ring Active Status is active
Can you also add  "show ccm
Can you also add  "show ccm-manager" and run "debug voip ccapi inout", "debug voip dialpeer inout" along with the "debug vpm signal".  It will give the forum a better view of the entire call.
Community Member
Please find it. Only one call
Please find it. Only one call to the issue phone.
The phone is not ringing.
521
