Analog Polycom CCM 4.1.3 can't make conference calls
kbehymerisg
I have an analog Polycom phone that can't make conference calls. It is attached to Callmanager via a MGCP gateway on an fxs port. Is it possible to have an analog make more than 1 call if the phone supports it. This phone used to work with the original PBX.
gogasca
Level 10
Level 10
Support for conferencing on analog FXS is limited to gateways configured for SCCP - see the following for more info, but hookflash can only intiate transfer when the gateway is configured for MGCP:
http://www.cisco.com/en/US/tech/tk1077/technologies_configuration_example091
86a00801f3b42.shtml
When a gateway is configured for SCCP, you can initate conferences and other supplimentary services:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124newft/124
t/124t2/ht1vg224.htm
Note that this SCCP config is currently limited to VG224s running 12.4T
Would an ATA 186 work in this situation?
Yes, ATA running SCCP image will work.
