Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Analog telephony adapter
Hi experts
                    Can a ATA of any other compant like audiocodes etc can be integrated with the Cisco network and CUCM......as the VG202s are very costly for running the fax........plz reply....suggestions are also welcome for the ata187 ......
regard Nitesh
You can still configure any of the ATA186/187 on CUCM on any current releases.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
any ideas sir wats the price difference between VG202 and ATAs
I just uploaded a screenshot from the device drop down with the ATAs here
https://supportforums.cisco.com/message/4040586#4040586
Sorry, I don't work with prices, someone else will need to answer that.
java
java
Jamie wat i knw ATA hasnt got the IOS ....so it has to registered as  a fone....is it rite that it has two mac address other shifted by juz one.....
131
