Analog Voice Gateway 204
Experts
I have configured the analog voice gateway as per the attached file just confirm to me the config are perfect, fax protocol is cisco, if it is recommended to change please advice i have followed below links.
For Voice Gateway configuration
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42105-vg200-cfg.html
For Call manager MGCP gateway configuration
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/42101-cm-cfg.html#task3
And the below link little bit confusing me for the FAX protocol in section Telco — PRI — GW — MGCP — CUCM — MGCP — VG224 — Fax/Modem
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115742-fax-modem-call-flows-00.html#concept2
1 ACCEPTED SOLUTION
Hi Adam,
If you are running FAX:
If this is the call flow:
On both the Mgcp gateway make sure  you have Modem passthrough enabled by the commands below:
no ccm-manager fax protocol cisco
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711ulaw
(Bounce the MGCP stack by doing a "no mgcp/mgcp")
voice service pots
fax rate disable
Make sure you have that you have "Modem PassthroughRequired Field" drop through option on the CUCM/MGCP page enabled and T.38 disabled.
Rate the post accordingly.
Kevin
Experts,
you'll hints are very helpful. please suggest.
thanks
Hi Adam,
voice service pots
fax rate disable
Kevin
Re: Analog Voice Gateway 204
Good info Kevin (+5)
Yosh
HTH Regards, Yosh
Thanks Yosh
Dear Kevin,
instead of VG224 i have VG204
with fax protocol cisco the fax will not work??
what has to be selected for the FXS ports on the CUCM there are 3 option loop start, ground,pots??? what i have to choose
Hi Adam,
You can apply the command i mentioned in my earlier post for running modem passthrough.
Kevin
Hi Adam,
Check the snapshot  below:
Kevin
Hi Adam,
Forgot to add this, just make sure you do not have slip on the PRI, this how you would check it:
mf-access#show controller t1 0
    T1 0 is up.
    No alarms detected.
    Version info of slot 0: HW: 2, Firmware: 16, NEAT PLD: 14, NR Bus PLD: 22
    Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
    Data in current interval (850 seconds elapsed):
    0 Line Code Violations, 0 Path Code Violations
    0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
    0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Kevin
Thanks for the reply kevin,
voice service pots
fax rate disable
The above commands should be executed on analog VG204 and also on the Voice Gateway on which ITSP PRI is terminating.
correct me if  i am wrong.????
Hi Adam,
If the PRI is added as MGCP to the CUCM, then yes.
Kevin
thanks for the reply
but what click you for the slips,, on applying those modem passthrough commands will generate any slips???  because at current my PRI is stable.
242
