ANI Based Routing
Hi guys,
i have a customer who wants to route his calles based on the ANI.
Example:
The User forwarded his phone to a specific number, so all call will be forwarded. But there who should be able to call the User.
I thought i can get this to work on the h323 gateway, but dont get it to work.
Is there any way i can get this to work? I think the problem is that we have to match the ANI and also the DNIS in combination.
Best Regards
Daniel
ANI Based Routing
CUCM? CME? version?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
ANI Based Routing
CUCM 9.1 with H323 GW.
Hall of Fame Super Silver
ANI Based Routing
You can use the "Route Next Hop By Calling Party" feature on translation patterns, here is a good doc explaining how to block calls based on ANI, but you can apply the same logic to route calls:
https://supportforums.cisco.com/docs/DOC-18367
HTH, please rate all useful posts!
Chris
254
