Ann File missing
Hi all,
I got the logs from RTMT. I have one AnnRingBack.wav in TFTP/united_states but no where else. My Default network locale is Australia and Default User Local is English United States. Any suggestion? Thanks.
Gary
12:59:32.315 |-->CANNAudio::GetAnnouncement()
12:59:32.315 |-->CANNAudio::GetCodecString(4)
12:59:32.315 |<--CANNAudio::GetCodecString(4)
12:59:32.315 |   CANNAudio::GetAnnouncement() LocaleID(1) CountryID(2) AnnID(36) payload(.ulaw)
12:59:32.315 |   CANNAudio::GetAnnouncement() Ann(Alertingtone) AnnRingBack.wav(NW) AnnRingBack.wav(NW)
12:59:32.315 |-->CANNAudio::isFileExist(AnnRingBack.wav)
12:59:32.315 |   CANNAudio::isFileExist(AnnRingBack.wav) isUserLocale(F) UserLocale(1) nwLocale(2) isCustom(F)
12:59:32.315 |-->CANNAudio::GetLocale
12:59:32.315 |   CANNAudio::GetLocale Announcement network locale not found ID(2)
12:59:32.315 |<--CANNAudio::GetLocale
12:59:32.315 |-->CANNAudio::Alarm(36-Alertingtone)
12:59:32.315 |<--CANNAudio::Alarm(36-Alertingtone)
12:59:32.315 |<--CANNAudio::isFileExist(AnnRingBack.wav)
12:59:32.315 |   CANNAudio::GetAnnouncement() Ann file missing (AnnRingBack.wav) UserLocale(1) Country(2)
12:59:32.315 |   CANNAudio::GetAnnouncement() Ann(Alertingtone) File(/usr/local/cm/tftp/)
12:59:32.315 |<--CANNAudio::GetAnnouncement()
1 ACCEPTED SOLUTION
It is a missing wav file
It is a missing wav file because the AU network locale has not been installed on all the required servers. ANN will not depend on the user locale, it will depend on the network locale, because Ringback when provided by ANN is a network operation.
Please install the AU locale on all required servers and restart the services as instructed in the readme/release notes and then do the tests again.
How many servers do you have
How many servers do you have in the cluster and did you install the locales on all TFTP servers in the cluster?
Please rate useful posts.
Hi Grorge,Thank you for your
Hi Grorge,
Thank you for your reply. We haven't installed the AU locales yet (only combined locale for AU is available from Cisco) and we would like to confirm the problem is from locale because the AU and US local language won't make much difference for AU users.
Thanks and regards,
Gary
From the logs it seems like a
From the logs it seems like a missing locale. Maybe someone else might chime in.
Thank you.
Thank you.
Glad to help!
Glad to help!
64
