Announcement of the Annunciator stops
I'm running CUCM 7.1.3.30000-1 and when I call a unallocated number, the annunciator starts the announcement, but stops in the middle of the message.
i.e. "Your call can not be....". About every 15-20 time the announcement is played correct.
For your information, this is a multi cluster environment and for this there is a route pattern pointing to gatekeeper via ICT (tunneled QSIG).
On gatekeeper I see the call coming in.
In RTMT I see, that there are enough ressources available.
Any idea, why this happens?
Peter
Everyone's tags (2)
1 ACCEPTED SOLUTION
Looks like a possible leak, i shall have a look around for any possible bugs, in the meantime can you restart the IPVMS service on the servers running this service and see if it alleviates the issue.
Niket
Kindly rate useful posts!!!
Niket
Hi Niket
It seems, that restarting IPVMS service solved the issue.
Thanks for the hint!
Cheers
Peter
Hi Peter,
Glad i could help.. i shall keep digging to see if there are any issues reported with Ann with the version you are running on.
Thank you for the positive feedback.
Niket
182
