Community Member
Annunciator Prompts
Hi all,
I have a customer that wants the callmanager to play a prompt saying that a user is not allowed to make a call because that user as no privileges to call that prefixes when a user in fact as no privileges, by default the callmanager plays a prompt saying that is not possible to make the call please consult your directory number...
Is there a way to do this?
Thanks in advance
Re: Annunciator Prompts
If you look in the help index
under, "annunciator" and then choose the "announcments" option, you'll see a disclaimer about this that essentially says that there is no tool yet to manually modify these files.
However, it looks like you can create your own modified wav files and then modify the
annunciator.xml file to use those files.
The annunciator.xml file is in: C:\Program Files\Cisco\TFTPPath\United_States
The actual wav files are in a langauge directory (on my server, that directory was
Please review the help index and the annunciator.xml file and let me know if you have
additonal questions. You should be able to just change create files of your own, then
modify the .xml file to use them.
The only way to know what prompt
is playing (the actual file name) would be to set CCM traces and examine them.
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_0/sys_ad/4_0_1/ccmcfg/b04ann.htm#1042536.
This information was take from the following post:-
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1ddfe31a/0#selected_message
Hope this helps.
Allan.
Community Member
Hi Allan,
I'm using cm 5.1.2b, does this procedure also apply to 5.X ?
Unfortunately I have not been able to find a specific document which details customising the annunciator as they do for 4.1x.
However, the annunciator files and tones will also be wav in format under the activepartition. The problem will be indentify the path and which files are applicable and the annunicator xml file. If you run 'file list active <> detail' from the CLI this will give a comprehensive list of files.
If you are looking at testing this, then I would recommend changing the Annunciators on a VMWare session or on non production CallManager first. I will look into doing the same.
Allan.
187
