Annunciator update !!
anis_cisco
hi all,
can any one tell me how to upload new file for annunciator in CCM 6.0 ???
Anis
6 Replies 6
Jaime Valencia
You CANNOT upload new files to ANN
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
hi java,
I was looking to configure my customize tone while i transfer call (instead of ring back tone), and from CCM 6.0 system guide i got to know that we can do this via annunciator !!!!
so thats why i was trying to upload file in annunciator but i couldnt ....
can you please guide me how i can achieve that ????
As mentioned above, you do not have the ability to do this.
Yes,
im agreed with java but im asking that how can i configure my system to play customize prompts while transfering call ??? is there any other way instead of annunciator ???
Seriously? I'll rephrase my answer I guess: NO
UCM does not provide the ability to customize ringback. Phones allow end users to customize the incoming call ring tone but that's it.
Its strange that UCM doesnt support this .
.. any ways thanks for your time and reply.
Anis
