Community Member
Annunciator update !!
hi all,
can any one tell me how to upload new file for annunciator in CCM 6.0 ???
Anis
Re: Annunciator update !!
You CANNOT upload new files to ANN
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Community Member
hi java,
I was looking to configure my customize tone while i transfer call (instead of ring back tone), and from CCM 6.0 system guide i got to know that we can do this via annunciator !!!!
so thats why i was trying to upload file in annunciator but i couldnt ....
can you please guide me how i can achieve that ????
VIP Super Bronze
As mentioned above, you do not have the ability to do this.
Community Member
Yes,
im agreed with java but im asking that how can i configure my system to play customize prompts while transfering call ??? is there any other way instead of annunciator ???
VIP Super Bronze
Seriously? I'll rephrase my answer I guess: NO
UCM does not provide the ability to customize ringback. Phones allow end users to customize the incoming call ring tone but that's it.
Community Member
Its strange that UCM doesnt support this .
.. any ways thanks for your time and reply.
Anis
379
