Anonymous Call Rejection with CUCME
I'm running CUCME on a 2921 with ios 15.0(1).  I'm wondering if it is possible to block incoming anonymous/unknown numbers from our PRI and if so, how I'd go about implementing it?
Josh
Blue
You can use "Call Blocking Specific Calling Numbers" in below link.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con13
Ronak patel
Please rate Helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
So applying a rule similar to
voice translation-rule 1
 rule 1 reject /Unknown/
Should work?
Re: Anonymous Call Rejection with CUCME
Apparently it does not work.
VOICE(cfg-translation-rule)#rule 1 reject ?
     /WORD/  Matching pattern
VOICE(cfg-translation-rule)#rule 1 reject /Unknown/
         % Invalid input detected at '^' marker.
Any suggestions?
Finally got it working with the following:
voice translation-rule 6
rule 1 reject /^$/
rule 2 reject /[^0-9]$/
747
