another approach for Connection plar command
I configured  connection plar 1001 command under the FXO port which makes all incoming calls from the PSTN on this port to go directly to 1001 (Ip Phone) .
But the customer needs that all the incoming calls on this port to go directly to two different IP Phones( 1001 and 1002) at the same time .
How can i do that  ?
  • IP Telephony
Super Bronze
Create a shared DN accross the two phones and send the PLAR calls to that new DN.
Or create a hunt group including 1001 and 1002, and send the PLAR calls to the hunt pilot.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
The customer refused the shared line he'd like to send the PLAR calls to two different ephone-dn
If i used the hunt group it will prevent the 1001 and 1002 to ring at the same time
Hall of Fame Super Gold
"refused shared line" ?!?
That is the best way to have multiple phones ring at once, and do things like put on hold and pick it up on the other phone.
That's right but he has some SIP and others are SCCP and the mixed shared lines don't work (needs upgrade the CME to ver 9.0 )
If interested in alternatives, I also wrote a script for blast calling. It can be acquired at www.ciscoscripts.com
Hi Paolo,
The link doesn't work
Hall of Fame Super Silver
Thanks chris for the useful link I found the following config
voice hunt-group 4 parallel
pilot 1000
list 1001, 1002, 1003, 1004
final 2000
timeout 20
but i have a question what about if the IP Phones are mixed (SIP and SCCP) ?
Does it work too ?
552
