Community Member
answering calls thru Citrix
Does anyone know if this is even possible. I don't know if anyone is already doing this. we are using citrix and would like to be able to answer calls thru remote sessions. is this possible?
1 REPLY
Silver
Re: answering calls thru Citrix
Webdialer works great over citrix. It needs some SOAP programming to have the dialbutton in outlook. You need to program an outlook plug-in. If you use telesnap or xphone or another client based solution, you can indeed show some CTI- like functionality even under citrix.
98
