04-01-2007 06:49 PM - edited 03-14-2019 08:47 PM
We have a CCM v4.1 installed on Cisco windows 2000 and a Trend Micro Office Scan version 7.0.
Whenever we install the anti-virus, calls are dropping. So we uninstall it.
Can you or someone from Cisco help us on this? What are the things to consider and what setup?
I would appreciate it if you could include a link or print screen...
thanks,
robert
04-01-2007 07:09 PM
According to this link, v7.3 is supported on CCM v4.1.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00807f4093.shtml
04-01-2007 07:17 PM
Hi Ifulgenzi,
tnx for the quick reply.
But can you show me the setup pls? or just a normal setup would do?
thanks,
robert
04-01-2007 08:03 PM
According to this, there are no application specific notes available.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd800f8572.html
There is one for serverprotect, but i'm not sure if it applies.
http://www.ciscosystems.com/en/US/products/sw/voicesw/ps556/prod_bulletin0900aecd800f6182.html
You'll probably want to open a case with the TAC for more concrete info.
04-02-2007 12:15 AM
I can't open a a case with the TAC cause it's looking for a serial number and what serial will I provide? the CCM serial or the Physical server's serial?
04-02-2007 05:10 AM
Typically, this is the server's serial number. Of course, it needs to be under Smartnet or under warranty. But I'm not sure if the servers/CallManager has any warranty after purchase like 60 or 90 days.
You could always call them to open the case to. 1-800-553-2447.
04-11-2007 09:19 PM
Hi Ifulgenzi / Anybody,
It looks like we don't have warranty anymore.
So can someone help me provide the settings for Trend Micro OfficeScan version 7.3 (on CCM 4.1 server) installation? a print screen would be fine...
thanks a lot,
robert
04-12-2007 04:03 AM
For issues with third party products like Trend I would contact Trend support. I'm not sure how Cisco could resolve issues with Trend's product.
04-12-2007 04:54 AM
Hi!
Are calls dropped after 315sec?, Try to disable/uninstall firewall in Officescan.
