anunciator
How can you make the system message
go another language when someone mis diales a number
I havea customer that has sites in Brazil and as well as US
I have two device pools one
1 the us users get the english system message
2.- brazil device pool gets the english system message
how can i change it i already loaded the locale for brazil no work...
1 REPLY
Green
Re: anunciator
You can create your own modified wav files and then modify the annunciator.xml file to use those files.
The annunciator.xml file is in: C:\Program Files\Cisco\TFTPPath.
The actual wav files are in a langauge directory (on my server, that
directory was C:\Program Files\Cisco\TFTPPath\United_States
You can customize using the following link:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/4_0/sys_ad/4_
0_1/ccmcfg/b04ann.htm#1042536
121
