Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Any issues adding a Unity 5.x VM server to the same domain as a Unity 4.2
I would like to verify there are no issues related to adding a Unity 5.x voice messaging (not Unified) server to an existing AD domain with a Unity 4.2 voice messaging server. The 4.2 server is in production and the 5.x server is new. From what I can tell, the only requirement is that ADSchemaSetup.exe needs to be run from the Unity server that's at the latest release (5.x in this case). Are there any other items of concern or things to take note of? Thanks in advance.
Re: Any issues adding a Unity 5.x VM server to the same domain a
not really, as you already mentioned main concern is just to make sure to run the adschemasetup from the latest unity version in the domain
java
if this helps, please rate
java
www.cisco.com/go/pdi
Java, thanks for the reply. One other question came to mind after reviewing the installation guide. Is it necessary to run ForestPrep and DomainPrep when installing Exchange on the new 5.x Unity server? My guess is yes since it is the first Exchange 2003 server in the forest. The only other server is Unity 4.2 with Exchange 2000. Can someone confirm this? Thanks again.
97
