Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Any Limitations on OS Admin account creation?
Dear Team,
I would like to create 15 users accounts with the privileage level of 4 for the CUCM's OS Administration access. I would like to know is there any limitations that only a specific no. of users should be created on the CUCM Platform Access?
I am running with the CUCM and Unity Connections of 8.5.1
Mohsin..
1 REPLY
If you mean in the amount of users, no, there is currently nothing on limits for that.
They're just an entry in the Linux system with the level of privilege you want them to have.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
140
