05-18-2010 08:25 AM - edited 03-15-2019 10:48 PM
I currently have a CUCMBE 7.1.3 system with 150 users. This seems to run ok with out any performance issues.
I'm looking to add around 300 more users to this system.
Can the CUCMBE actually support this number of users in the real world ?
(It's a different question as to whether or not it's sensible to have this number of users on a single server solution.)
Andy
Solved! Go to Solution.
05-18-2010 09:13 AM
CUCMBE is supported with up to 500 users.
Table 1. System Capacity
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
05-18-2010 09:13 AM
java
05-18-2010 04:05 PM
Thanks for the info.
Is there anyone out there actually running 400+ users on a CUCMBE ?
