Any TAC engineer.Plz help
https://tools.cisco.com/bugsearch/bug/CSCtn81394
Symptom:
Fresh install, RU or system reboot fails with error "could not detect IMM Device"
Conditions:
On IBM's IMM based servers (7835/45-I3, 7816/25/28-I5) if a user manually disables in-band USB interface, then CUCM scripts cannot detect and configure hardware. This is a critical setting, its enabled by default, and is needed for CUCM scripts to work.
Workaround:
User should revert back manual changes to the in-band usb interface settings to default (enabled).
Plz help guys,how i can revert the integrated management module settings back to default :((((((((((((((((((((((((((((((((((((((((
This should be something you check with IBM, but this migth help, please check Page 63:
http://pic.dhe.ibm.com/infocenter/sonasic/sonas1ic/topic/com.ibm.sonas.doc/imm_users_guide_60y1465.pdf
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
281
