Any updates to TAC Case 48396653
Does anyone know if there are any updates to this? The case is a known issue where an MGCP GW does not support Caller ID when T1-CAS is being used. The workaround is to configure the GW as h323. thanks
1 ACCEPTED SOLUTION
Green
Re: Any updates to TAC Case 48396653
Caller ID is not supported on T1 CAS E&M. Nothing to do with H.323 or MGCP.
The only way to do Caller ID on T1 CAS is with T1 FGD. That is supported in
H.323, not MGCP. No plans afaik.
You can also do it in one direction only with T1 CAS FXS (send) and T1 CAS
FXO (receive) but this is typically used only for channel-bank connections
and not for PBX or PSTN connections. CCM supports only T1 CAS E&M with
MGCP, so if FXS or FXO signaling is an option in your situation, then that
too will require H.323.
Green
Thanks for the information
I configured "ring number 2" on my voice port and it works.
it is on FXO-GROUND-START signalling
119
