03-08-2009 10:45 AM - last edited on 03-25-2019 07:48 PM by ciscomoderator
A customer purchased a used 7940 that has a MGCP firmware load, and is also password protected. Needs to use it in a UC500 system with SCCP.
The phone doesn't respond to the normal sequence for defaulting a password protected 7940 (hold down the # key, etc.) and continues to try to boot up.
Is there any other way to get this phone to a factory default?
Mike
03-08-2009 11:17 AM
Hi Mike,
Maybe you could try method #2 below;
To reset the phone do the following:
Note that the phone must be on a network providing an IP address and TFTP server
address using DHCP and the phone must be powered via external power brick. The
Alternate TFTP setting is erased when using this procedure requiring that the
TFTP server address be provided by a DHCP server to get the phone upgraded.
1) Power off the phone
2) Hold down the '#'.
3) While holding '#', connect an AC adaptor to the phone.
4) Continue to hold '#' until the line buttons blink amber.
5) Release the '#' key.
6) Enter: 1 2 3 4 5 6 7 8 9 * 0 #
7) The lights should change color from amber to red. The phone is now resetting
to factory defaults.
If the above does not work, try the following:
6) Enter: 3 4 9 1 6 7 2 8 5 0 * #
to factory defaults
Hope this helps!
Rob
03-09-2009 08:49 AM
Thanks Rob,
I tried both suggestions with an AC adaptor but the phone still doesn't repond to holding down the # key. It just keeps going, and trying to boot.
Mike
