Any way to modify inbound dial peer on CME?
I have a voice application I need to test. It needs to run on the inbound dial peer for a call that is destined to an FXS port on the CME.
I tried to make a voip dial peer with "incoming called-number ." but this does not work, instead CME uses the hidden dial-peers for the ephones, and those don't seem to be able to be modified.
So I would like to place a call from an ephone to an FXS port, and configure my voice application to run on the inbound leg, is this possible?
1 REPLY
Re: Any way to modify inbound dial peer on CME?
Replying to my own post:
Here is how it can be done:
voice translation-rule 2
rule 1 /1001/ /1002/
voice translation-profile 2
translate called 2
application
service myapplication flash://myapplication.tcl
dial-peer voice 200 pots
destination-pattern 1002
port 2/0
dial-peer voice 300 voip
translation-profile outgoing 2
destination-pattern 1001
session target ipv4:172.16.2.2 <------------- This is the CME's IP address
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 301 voip
incoming called-number 1002
codec g711ulaw
no vad
123
