Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Anyway to shorten the call setup time for CallManager to PSTN?
Hi All,
Anyway to shorten the call setup time for CallManager to PSTN through voice gateway and CCME to PSTN? Seems the call setup time by default to PSTN is longer then using traditional PBX.
Best Regards,
Teru Lei
Re: Anyway to shorten the call setup time for CallManager to PST
you can shorten the interdigit timer value by performing these steps in Cisco CallManager:
Select Service > Service Parameters, and select server.
Find the TimerT302_msec* parameter, enter a value of 6000 and click Update. This sets the interdigit timer to six seconds.
Have the users test the phones and adjust as necessary.
Teru, you can also use # key to route the call after dialing the digits, that will route the call immediately.
//Jorge
Bronze
or you can revise your dial plan and see what is overlapping to cause the system to wait for the completed digits.
130
