Application password
amansoi_5
HI All,
Is it possible to keep different Application password(password which is used for logging into CUCM Administartion page) in CCM 5.x & 6.X? for PUB & SUB.
Is the same applicable for OS Administration passwords as well?
regds,
aman
NO, BOTH users could access BOTH server. as i already mentioned this is PER CLUSTER, NOT PER SERVER
java
if this helps, please rate
java
5 Replies 5
dezoconnor
Level 4
Level 4
Hi Aman,
You can have multiple end users configured for administration access to callmanager. Under the Permissions Information on the End user page add the Group "Standard CCM Super User"
Don't think you can have different logons for OS Admin.
Jaime Valencia
CUCM already has MLA for this, it's not independent per server. it's per cluster
you can create OS accounts if needed, refer to OS admin guide for instructions on your version
java
java
My concern was that can we have one USER like CCMADMINISTRATOR which has different password for PUB and same user i.e. CCMADMINISTRATOR which has different password for SUB.
regds,
aman
java
java
thanks....
