Silver
apply config button on CallManager 7.1
Does anyone know what the apply config button on CallManager 7.1 REALLY does?
The release notes makes mention of a "seamless integration feature" but I can't find anything else.
Hall of Fame Super Red
Re: apply config button on CallManager 7.1
Hi Michael,
Synchronization of Configuration Settings
Description
Cisco Unified Communications Manager Release 7.1(2) allows you to use a single button in Cisco Unified Communications Manager Administration to synchronize various devices with the most recent configuration changes. This button gets called "Apply Config" when it is located on a configuration window and gets called "Apply Config to Selected" when it is located in a Find and List window. These buttons apply any outstanding configuration settings in the least-intrusive manner possible. (For example, some devices may not require a reset/restart to apply the configuration.)
Cisco Unified Communications Manager Administration Configuration Tips
To synchronize a device with the most recent configuration changes, perform the following procedure.
Procedure
Step 1 Navigate to one of the windows that are listed in Table 24. Table 24 lists all the windows in Cisco Unified Communications Manager Administration, organized by menu, that provide the configuration synchronization function.
The Find and List window for the applicable items displays.
Step 2 Choose the search criteria to use.
Step 3 Click Find.
Step 4 The window displays a list of items that match the search criteria.
a. If the window shows a button that is called Apply Config to Selected, perform the following tasks (otherwise, proceed to b.):
-Check the check boxes next to the items that you want to synchronize. To choose all items in the window, check the check box in the matching records title bar.
-Click Apply Config to Selected.
-Proceed to Step 5.
b. If the window does not show a button that is called Apply Config to Selected, perform the following tasks:
-Click the item that you want to synchronize.
-The configuration window for the item that you clicked displays.
Make any additional configuration changes.
Click Save.
Click Apply Config.
Proceed to Step 5.
Step 5 The Apply Configuration Information dialog displays.
Note The device(s) may need to restart for configuration changes to take effect.
Click OK.
....continued on next page
....from previous page
Table 24 Windows for Synchronizing
Navigation Path to Window Window Name
System Menu
System > Cisco Unified CM
Cisco Unified CM Configuration
System > Cisco Unified CM Group
Cisco Unified CM Group Configuration
System > Date/Time Group
Date/Time Group Configuration
System > Region
Region Configuration
System > Device Pool
Device Pool Configuration
System > Enterprise Parameters
Enterprise Parameters Configuration
System > Security > Phone Security Profile
Phone Security Profile Configuration
System > Security > SIP Trunk Security Profile
SIP Trunk Security Profile Configuration
Call Routing Menu
Call Routing > Dial Rules > SIP Dial Rules
SIP Dial Rule Configuration
Call Routing > Route Filter
Route Filter Configuration
Call Routing > Route Hunt > Route List
Find and List Route Lists
Call Routing > Route Hunt > Hunt List
Find and List Hunt Lists
Call Routing > Class of Control > Partition
Partition Configuration
Call Routing > Intercom > Intercom Route Partition
Intercom Partition Configuration
Call Routing > Intercom > Intercom Directory Number
Intercom Directory Number Configuration
Call Routing > Directed Call Park
Directed Call Park Configuration
Call Routing > Directory Number
Media Resources Menu
Media Resources > Annunciator
Find and List Annunciators
Media Resources > Conference Bridge
Find and List Conference Bridges
Media Resources > Media Termination Point
Find and List Media Termination Points
Media Resources > Music On Hold Server
Find and List Music On Hold Servers
Media Resources > Transcoder
Find and List Transcoders
Voice Mail Menu
Voice Mail > Cisco Voice Mail Port
Find and List Cisco Voice Mail Ports
Voice Mail > Voice Mail Profile
Voice Mail Profile Configuration
Device Menu
Device > CTI Route Point
Find and List CTI Route Points
Device > Gatekeeper
CTI Route Point Gatekeepers
Device > Gateway
Find and List Gateway
Device > Phone
Find and List Phones
Device > Trunk
Find and List Trunks
Device > Device Settings > Softkey Template
Softkey Template Configuration
Device > Device Settings > SIP Profile
SIP Profile Configuration
Device > Device Settings > Common Device Configuration
Device > Device Settings > Common Phone Profile
Common Phone Profile Configuration
Application Menu
Application > Cisco Unified CM Attendant Console > Pilot Point
Find and List Pilot Points
GUI Changes
Cisco Unified Communications Manager Administration added the "Apply Config" or "Apply Config to Selected" buttons to the windows that are listed in Table 24.
Service Parameter and Enterprise Parameter Changes
The Enterprise Parameters Configuration window (System > Enterprise Parameters) contains the "Apply Config" button.
-https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/rel_notes/7_1_2/cucm-rel_notes-712a.html#wp1240661
Hope this helps!
Rob
Silver
Thanks Rob, that's a start.
Just have to figure out what changes would (traditionally) automatically restart the phone. (like DN page changes.)
What changes require a reset/restart instead of apply config. Sounds like apply config can be pressed 99% of the time and if a restart or a full reset is required then it will take care of that for you. But there's the question on the line config pages that would traditionally restart the phone without having to press anything.
Thanks for the reply.
1997
