Community Member
Applying FAC-CMC for multi Tenant Environment
Hi all,
Design constraint!!!!
Lets say A CCM Cluster has separate partitions for each client,& FAC/CMC doesnt belong to any partition by design, so If FAC/CMC applied on any route pattern then it will be applied to whole cluster for outgoign calls.
Only work around is to create complete dial plan(route pattern) for each customer, but that route pattern will be assigned to that customer's partition only.. This will make the configuration tedious but functional
As configuring CMC/FAC @ Route Pattern(RP) level will not be practical in multi tenant design, so there is need in CCM design to provide CMC/FAC on either DN OR As a Service subscribe to device profile.
Above is the practical scenario m facing @ work.
Appreciate the community for elaboration.
Silver
Re: Applying FAC-CMC for multi Tenant Environment
if you feel that the product should have that capability get in touch with your AM and see the possibility of opening a PER for that
javalenc.
java
if this helps, please rate
www.cisco.com/go/pdi
Community Member
Is there a way to raise suggenstions to Cisco R&D team
PER = Product Enhancement Request
talk to your AM in order to see if you can present one. Be aware that just the fact of presenting it does not mean it will be implemented in a future release
javalenc
java
Community Member
page not found!!!!!!!!!!!!!!!
137
