Community Member
Are 7911 supported on 7.x?
This be a noddy question, but the SRND mentions the following -
The Cisco Unified IP Phones 7902G, 7905G, 7910G, 7910G+SW, and 7912G are no longer available
for sale, but they are still supported by Cisco Unified Communications Manager 7.x.
It does not mention the 7911, does this mean it is not supported?
James
Hall of Fame Super Red
Re: Are 7911 supported on 7.x?
Hi James,
The IP Phone 7911G is supported on CUCM 7.x (not to worry :)
Cheers!
Rob
Community Member
Cheers Rob and thanks for the quick response.
I just thought the info from the SRND was a bit misleading and before l went gun ho, l would check.
Thanks again.
James
Hi James,
You are most welcome my friend! Better safe than sorry :)
Cheers!
Rob
115
