AS5300, E1 pri, no clock source internal
Hi NetPro
I have problem with a AS5300 and E1 pri interface, the AS5300 have 4 E1 pri contected and working but i need attach a another E1, but when i try to configure the clock source internal, the command it's no avalaible.
regards
fixie rider
Hall of Fame Super Gold
Re: AS5300, E1 pri, no clock source internal
Can you post "show controllers e1" and a console log of the clock options presented for the 5th controller.
thanks, I send a document.
fixie rider
Can you try configuring clock source line primary for the interface connected to master clock ?
And the console log unsuccesful configuration for a controller you want to use clock internal.
is not posible configure the clock
fixie rider
You should have mentioned that is a 5350, not 5300.
You need to configure you primary clock source first (dial-tdm-clock):
http://www.cisco.com/en/US/docs/routers/access/as5350xm/software/configuration/guide/54bas2.html#wp1055650
409
