AS5300 with elastix
Hello all,
I am trying to connect elastix with AS5300 cisco gateway via sip trunk
here is router config
sip-ua
authentication username XXX password XXX
retry invite 2
retry response 2
retry bye 2
retry cancel 2
retry options 2
registrar ipv4:192.168.113.211:5060 expires 3600
sip-server ipv4:192.168.113.211:5060
dial-peer voice 113 voip
destination-pattern 67520004.
session protocol sipv2
session target ipv4:192.168.113.211:5060
dtmf-relay rtp-nte
codec g729br8
elastix sip trunk
General Settings
Trunk Description:
Outbound Caller ID:
CID Options:
Maximum Channels:
Disable Trunk:Disable
Monitor Trunk Failures:
dial peer
host=192.168.113.6
username=XXX
secret=XXX
type=peer
canredirect=no
canreinvite=no
allow=g729br8
disallow=all
user detail
secret=XXX
type=user
context=from-trunk
username=XXX
fromuser=mena
qualify=no
canreinvite=no
allow=g729br8
disallow=all
always when i try to call any number give me a circuit busy message, is any document or help to such like this configuration between elastix and as5300 cisco gateway
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
AS5300 with elastix
No trace, no troubleshoot.
AS5300 with elastix
Router config is incomplete, it must have at least one dial-peer pots.
AS5300 with elastix
my network configuration as following :
as5300 working as h323 voice gateway on f0/0 and i want to add a sip gateway to as5300
here is the complete configuration of the as5300 VGW
Current configuration : 4393 bytes
version 12.4
hostname XX
boot-start-marker
boot system flash c5350-is-mz.124-11.T4.bin
boot system flash c5350-is-mz.123-3g.bin
no boot startup-test
boot-end-marker
logging monitor critical
enable secret 5 $1$QhHi$sv47RYidJJvFcyRmv5ved1
resource-pool disable
no aaa new-model
clock timezone utc 2
spe default-firmware spe-firmware-1
ip cef
no ip domain lookup
isdn switch-type primary-net5
voice call send-alert
voice rtp send-recv
voice service pots
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
voice service voip
h323
  h245 tunnel disable
  h245 caps mode restricted
modem passthrough nse codec g711alaw
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server
voice class codec 1
codec preference 1 g729br8 bytes 60
voice translation-rule 1
rule 1 /^9#0/ /999/
voice translation-profile test
translate called 1
fax interface-type fax-mail
dial-control-mib retain-timer 1000
dial-control-mib max-size 1200
username x password XX
username X password XX
controller E1 3/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 3/1
framing NO-CRC4
ip address 192.168.14.80 255.255.255.0
load-interval 30
duplex full
speed 100
h323-gateway voip interface
h323-gateway voip id gk-zone1 ipaddr 192.168.14.70 1719 priority 126
h323-gateway voip h323-id AlkanVGW
h323-gateway voip tech-prefix 1#
h323-gateway voip bind srcaddr 192.168.14.80
interface FastEthernet0/1
ip address 192.168.113.6 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn timer T310 400000
isdn incoming-voice modem
isdn sending-complete
no cdp enable
interface Serial3/1:15
no ip address
encapsulation hdlc
no cdp enable
interface Group-Async0
no ip address
encapsulation slip
group-range 1/00 1/59
ip route 0.0.0.0 0.0.0.0 192.168.14.33
ip route 10.0.0.0 255.0.0.0 192.168.14.254
ip route 10.20.1.0 255.255.255.240 192.168.14.33
no ip http server
snmp-server community xxx
control-plane
voice-port 3/0:D
cptone EG
bearer-cap Speech
voice-port 3/1:D
cptone EG
bearer-cap Speech
dial-peer voice 2 pots
destination-pattern 0.
direct-inward-dial
port 3/0:D
dial-peer voice 1 voip
tone ringback alert-no-PI
destination-pattern .
progress_ind setup enable 3
session target ras
codec g729br8 bytes 60
fax-relay ecm disable
fax rate 9600
dial-peer voice 3 pots
direct-inward-dial
port 3/1:D
dial-peer voice 1234 voip
destination-pattern 110.
session target ipv4:10.181.24.241
codec g729br8
dial-peer voice 122 voip
destination-pattern 122.
session target ipv4:10.181.28.245
codec g729br8
dial-peer voice 121 voip
destination-pattern 121.
session target ipv4:10.181.28.237
codec g729br8
dtmf-relay rtp-nte
codec g729br8
dial-peer voice 114 voip
gateway
timer receive-rtp 1200
sip-ua
authentication username xx password xx
retry invite 2
retry response 2
retry bye 2
retry cancel 2
retry options 2
notify ignore substate
ss7 mtp2-variant Bellcore 0
ss7 mtp2-variant Bellcore 1
ss7 mtp2-variant Bellcore 2
ss7 mtp2-variant Bellcore 3
line con 0
line aux 0
line vty 0 4
password xx
login
line 1/00 1/59
modem InOut
scheduler allocate 10000 400
ntp clock-period 17180036
ntp server 192.168.14.33
end
i made this dial peer 113 and sip-ua in the previous code to add elstix as a sip proxy in the network and use a sip phone too beside h323
Re: AS5300 with elastix
Your voip DPs need to have session protocol sipv2. Otherwise, they use H.323
Then you can take "debug ccsip message" with "term mon" to see what happens.
AS5300 with elastix
only i want apply sip gateway on int f0/1 to configure sip phone going out through pstn. and i configured session protocol in dial-peer 113 and the outage call (PSTN) should went out throurgh dial-peer 2 so should i configure sip session protocol in dial-peer 2
Thank you very match for your interest
AS5300 with elastix
AS5300 with elastix
realy, thank you for your interest, i had a doubt that it will work. Can you further recommend me sip proxy or server working with as5300 and has a good billing system.
but any way thanks alot  for your help.
AS5300 with elastix
Hi Mena,
could you please describe what hardware are you using with the AS5300? E1 card/ VoIP card/ DSPs?
Thanks a lot.
1613
