Community Member
AS5350 Malfunction
I have a Cisco AS5350 with 8 E1 links attached to it, this means 240 simultaneous calls. The GW works fine just for half a day with an average call volume of 230. After that, the GW starts dropping calls and the average call volume drops to 80.
Is there a reason for this behavior?
Cisco IOS Software, 5350 Software (C5350-IS-M), Version 12.4(9)T7, RELEASE SOFTW
ARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:52 by prod_rel_team
ROM: System Bootstrap, Version 12.3(12r)PI6b, RELEASE SOFTWARE (fc1)
Gateway_WS_NGT uptime is 17 hours, 4 minutes
System returned to ROM by reload at 15:50:32 VE Tue Oct 14 2008
System restarted at 15:51:25 VE Tue Oct 14 2008
System image file is "flash:c5350-is-mz.124-9.T7.bin"
Cisco AS5350XM (BCM) processor (revision 0x22) with 393215K/131072K bytes of mem
ory.
Processor board ID JAE1210AKSR
SB-1 CPU at 750MHz, Implementation 1025, Rev 0.3, 256KB L2 Cache
Last reset from IOS reload
Manufacture Cookie Info:
EEPROM Version 0x4, Board ID 0x4C3,
Board Hardware Version 2.7, Item Number 800-6571267-03,
Board Revision A0, Serial Number JAE1210AKSR.
Processor 0x0
2 Gigabit Ethernet interfaces
254 Serial interfaces
8 Channelized E1/PRI ports
512K bytes of NVRAM.
125440K bytes of ATA External CompactFlash (Read/Write)
Community Member
Re: AS5350 Malfunction
I forgot to mention that the H323 cause code 47 (No resources) form other peer, starts increasing very rapidly.
Community Member
DSP problems?
So far i know, Cisco recommends to use max 6E1s in together in a gateway.
141
