AS5350 perfomance ?
Whan is the value of PPS (packet per second) for AS5350. Is it correctly to speek about PPS for access server ?
Hall of Fame Super Gold
Re: AS5350 perfomance ?
No it is not. PPS is for router/switches that move packets from an interface to another, while the voice gateway does a different job.
Anyway, all the AS5000 have performance sufficient to support all the PRI circuit you can install in them. That is, for example, if the 5350 has a maximum of 8 x E1 (I don't remember now), it will work as advertised.
Then again, if you make the count of how many PPS is that, you see is quite a small number.
thank you
201
