AS5400 FGD T1 SIP Disconnect Message question
We have an AS5400 gateway connected to an Excel Switch via DS3 split to T1s on a mux.
The T1s are configured with fgd-eana configuration.
controller T1 7/0:8
framing sf
ds0-group 1 timeslots 1-24 type fgd-eana mf ani-dnis
Below is the dial peer configuration.
dial-peer voice 1234 voip
permission orig
description TEST
huntstop
voice-class codec 1234
session protocol sipv2
incoming called-number 1234
no vad
dial-peer voice 1235 pots
permission term
description TEST
destination-pattern 1234
no info-digits
port 7/0:8:1
forward-digits 4
Calls are connecting fine. Its the disconnect where the issue is.
Received:
INVITE sip:12348889990000@10.10.10.10 SIP/2.0
Via: SIP/2.0/UDP 20.20.20.20;rport;branch=z9hG4bK7tK13p814SFXa
Max-Forwards: 69
From: "+15556667777" <sip:005556667777@20.20.20.20;isup-oli=00>;tag=DXvcp6S56j92c
To: <sip:12348889990000@10.10.10.10>
Call-ID: e669b2cc-9bb8-122f-078b-0019b9dde139
CSeq: 21309657 INVITE
Contact: <sip:gw+10.10.10.10@20.20.20.20:5060;transport=udp;gw=10.10.10.10>
User-Agent: FSX-UAC/1.2
Allow: INVITE, ACK, BYE, CANCEL, OPTIONS, MESSAGE, UPDATE, INFO, NOTIFY
Supported: timer, precondition, path, replaces
Allow-Events: talk, hold, refer
Content-Type: application/sdp
Content-Disposition: session
Content-Length: 233
Remote-Party-ID: "+15556667777" <sip:005556667777@20.20.20.20>;party=calling;screen=yes;privacy=off
Sent:
BYE sip:gw+10.10.10.10@20.20.20.20:5060;transport=udp;gw=10.10.10.10 SIP/2.0
Via: SIP/2.0/UDP  10.10.10.10:5060;branch=z9hG4bKB21F28928
From: <sip:12348889990000@10.10.10.10>;tag=5491E944-1265
To: "+15556667777" <sip:005556667777@20.20.20.20;isup-oli=00>;tag=DXvcp6S56j92c
Date: Wed, 07 Dec 2011 20:57:29 GMT
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1323291503
CSeq: 101 BYE
Reason: Q.850;cause=16
Content-Length: 0
When the disconnect message is sent, the other end does not recognizes the message and call hangs.
The BYE message looks a little odd.
First is the initial BYE message has the field from Contact in the INVITE message.
Second, the From and To fields are flipped.
Would any of the two reasons I just mentioned be the cause of the call hanging?
Any help would be greatly appreciated.
Thank you.
Everyone's tags (4)
453
