AS5400 hardware conferencing / transcoding
Is it possible? Can anybody send me a configuration guide? THANKS!
Re: AS5400 hardware conferencing / transcoding
Hi, do have DSP inside it?
Answer is simple, if you have DSP then you can,if you don't have you can't.
You can see this link:http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
I have 16 PRIs and 20 x S5X-PVDM2-64, so I thought 4 S5X-PVDM2-64 are available for conferencing issues.
But I haven't found any document in Cisco talking about Conferencing & Transcoding in AS5400 devices.
Has anybody seen any document of configuration?
Thanks!
Hi Alicia,
The 5x00 platforms do not support conferencing/transcoding/MTP. They are not intended to do any type of SCCP with CUCM.
There is a new platform, the VGD-1T3, which can do this.
I would suggest looking into that if you need to do conferencing / transcoding.
-nick
320
