As5400 Questions
General questions on AS5400.Currently have 4 As5400 (12.3(12)being utilized in a VOIP solution.In the past 2 weeks there have been a few PRI's that have been removed and new ones added to 2 of the gateways.there also has been changes made to dial-peers.We are now experiencing Disconnects to XML seesionss (call will disconnect during ISN session)on-net calls losing audio (white noise is heard,call will return if you stay on line)All this is intermittent but can be duplicated.With all the changes made to AS5400,is a re-boot required?Could the changes lead to these type of problems?
1 REPLY
Hall of Fame Super Gold
Re: As5400 Questions
The 5400 data structures may have inconsistencies and causing trouble. At the time you schedule a reboot, also update to 12.3(21) and you will benefit of all bug fixes that have been incorporated since the code you run now.
102
