ASA 5505 and CME
Hi all recently i have configured an ASA 5505 and a cisco CallManager express, i have defined in the ASA dhcp the OPTION 150 for the ip phone to get their configuration file and i have enabled skinny inspection as the following:
LabASA_CME(config)# policy-map type inspect skinny skinny-map
LabASA_CME(config-pmap)# parameters
LabASA_CME(config-pmap-p)# enforce-registration
LabASA_CME(config-pmap-p)# match message-id range 0x0 0xFFFF
LabASA_CME(config-pmap-p)# drop log
LabASA_CME(config)# class-map inspection_default
LabASA_CME(config-cmap)# match default-inspection-traffic
LabASA_CME(config)# policy-map skinny_policy
LabASA_CME(config-pmap)# class inspection_default
LabASA_CME(config-pmap-c)# inspect skinny skinny-map
LabASA_CME(config)# service-policy Skinny_policy global
But the IP Phone still stuck in the registration part and when i sniff packet over my inside network where the IP Phone are installed i don't get any reponse from the CME
thanks for helping me out
1 REPLY
Bronze
Re: ASA 5505 and CME
If you can have the cme and the router talk directly without going thru the asa, it would be simpler. CME being a router does not need firewall and would see only SIP to the eternal world.
In that case you setup a static inside nat tranalstion for port 5060 to the cme:
ip nat inside source static udp 5060 interface 5060
307
